I can't answer a question, begin_repeat automatically follows
It does not allow to complete the question "observaciones", it continues with the next repetition after answering the question "copa" without answering the question "observaciones ".
XLSForm Online v2.3.3
The enumerator answers the question "copa"
It does not allow the enumerator to answer the question "observaciones", it automatically goes to the next repetition
Prueba_plantilla.xlsx (13.2 KB)
Hi @Fredy_Angarita
you are using quick appearance in that select_one question, that means the app should navigate forward automatically one you answer that question. I agree that in field-list groups when there are questions below it should probably just scroll down but it doesn't work like that.
Thank you very much for the explanation, I understand ... I had not read it https://xlsform.org/en/ref-table/, I still have to search. You're very kind.
