Good morning ODK Community?
I am working on a form with 3 questions.
Question 1 (Q1) and Question 2 (Q2) have integer fields.
Question 3 (Q3) is a single select (Yes/No).
I want to make Answer for (Q3) to be "Yes" only if the response in Q1 is
equal to the response in Q2. Other wise Q3 will only accept a "No" Response.
In short;
Q3="Yes" if Q1=Q2 otherwise Q3 only accepts a "No" choice.
Thank you advance.
Louis...
constraint:
( selected(${Q3},'Yes') and ${Q1} = ${Q2} ) or ( selected(${Q3},'No') and
${Q1} != ${Q2} )
In short;
Thank you advance.
Louis...
Thank you for the quick response.
It works now.
The issue has been resolved.
Many thanks for the technical support provided.
Louis...
On 22 Jan 2016 08:25, "Mitch Sundt" wrote:
constraint:
${Q1} != ${Q2} )
In short;
Thank you advance.
Louis...
