I have a xlsform where its calculate auto i.e. total Male and total Female. This two values should be equal base on distribution paper if not it shouldn't be go next question.
Is there way I can make formula, if both value are not equal then no go to next question?
@Grzesiek2010 is right you need to use constraints. And you will find the solution for your question. We are not getting your question please be detailed for your questions.
Thanks Arif for your support. My question is if both total are not equal it shouldn't go to signature. As I am new user I cannot upload file. Please find screen shot.
