Image Missing from Survey
I have a survey that calls in for 6 images (3 as side notes and 3 within questions).
the images are not showing althought they are successfully uploaded into ODK and downloaded with form.
**2. What app or server are you using and on what device and operating system? Include version numbers.**Using android from Samsung, and other mobiles, and bluestacks on pc.
Rename the image from jpg to png, resize the image, review naming
Upload a survey with image as NOTE and as question
Hi @LaraVR
Did you see this topic: Images not appearing on ODK Collect
Looks like the same issue, please check this answer Images not appearing on ODK Collect
That is right! I figured out if I put the pictures in 2 questions it would show. I needed to list only one picture in the xlsform cell, and IU had 2
Thank you for your quick response.
