New camera image for both the selfie camera and the main camera does not work when the image is either resized from ODK collect Image size settings or from the form itself using the max-pixels settings to the very small (640px)
ODK Collect v2022.1.1
Redmi Note 9 (M2003J15SS)
MIUI version 12.5.3 Stable(RJOIDXM)
Android 11 RP1A.200720.011
The problem happened earlier in Android 10 and other newer Android 11 devices work so I have tried to update the android to the latest version as well as reinstalled the application. However, upon testing the demo form, I was able to make the camera work by leaving the image to the default original size and changing the image settings to other sizes apart from the very small (640px)
This will not apply to all smartphones.
Download / Reinstall ODK Collect
Download Demo Form
Go to Project Settings -> Form Management -> Form filling -> Change Image Size settings to Very small (640px) for “Maximum pixels of the long edge of the image”
Open All widgets form and jump to Image widget without Choose button or Selfie widget
Take Picture
The error message “Selected file is not a valid image” should be shown.
Thanks for reporting the issue. I've tried to reproduce it but to no avail (I've used 4 devices) so it might be difficult. However I believe there might be something wrong in the app so I reported the issue in our repository https://github.com/getodk/collect/issues/5033 and I will try to spend some more time on it soon.
I have also just experienced this today similarly to what was reported by @erigmac and @Oscar_Orozco .
Lenovo TB-8505F
Android 10
image question type with parameters set to max-pixels=600
Error message = "Selected file is not a valid image"
I have read the issue and your description for the pull request discussion on GitHub, thanks for the investigation and fix
Just a quick clarification: is v2022.1.1 only available to beta testers at the moment or already released to any ODK users? (I am trying to understand if this has an impact on active data collection and if I need to quickly increase the resolution of pictures collected by ODK while waiting for the fix to be released/deployed - although I did not get nay feedback about this from the field, but this may have gone unnoticed)
The issue is tricky it doesn't occur on all devices and on some devices it occurs only if we scale images down to really small ones like 100px (longer edge) so maybe your users are lucky and not affected.
We already have a fix for the issue and are going to release a new version of the app with it soon.
