rizwan7
February 9, 2018, 9:03am
#1
I tried adding pictures to every answer choice for a multiple choice question, but when I run it on ODK collect it doesn't display any images.
I uploaded the XML file with images on ODK aggregate.
It gives this error: File /storage/emulated/0/odk/forms/Pole load-media/untitled.jpg is missing.
Even when I have the images in that folder in the device storage.
The latest ODK collect and Samsung galaxy J series android phone
I tried moving the images folder and the XML file in one folder before uploading it on ODK aggregate from my computer but it didn't work.
I also tried putting the images and XML file in one folder in my android phone but no luck.
Please help me. I really need it please
Hi @rizwan7
Please take a look here https://docs.google.com/spreadsheets/d/1af_Sl8A_L8_EULbhRLHVl8OclCfco09Hq2tqb9CslwQ/edit#gid=0 it's an example form with all widgets which contains choices with images too.
If you think that you do everything well, please attach your form and we can take a look.
Regards,
Grzegorz
rizwan7
February 10, 2018, 1:08am
#3
Thank you for your reply. I figured out the solution. It appeared that I wasn't using the correct picture format in my XLS form.
I'm facing another problem. When I upload my form into ODK aggregate, I don't see anything in the submissions tab, other than the name of the form.
However I can use the get the form in ODK collect and everything works fine.
I have attached a picture here for reference:
I'm also attaching the picture of the form management tab where it shows the uploaded form as file.
I would really appreciate if you could help me out. Thank you.
What format was it?
I’m facing another problem. When I upload my form into ODK aggregate, I don’t see anything in the submissions tab, other than the name of the form.
What message do you get after uploading in ODK Collect? Success or maybe any erro message?
hedi
July 9, 2018, 3:10pm
#5
Hi, All
I'm facing the same problem. I set up the form to include two languages: English and Arabic.
the images appear with the English language but when I switch to the Arabic language I can only read the metadata of pictures and the pictures are not displayed.
Thank you
According to the doc you need to add separate media columns for each language as well: http://xlsform.org/ref-table/#survey
Here is an example: testY.xlsx (5.0 KB)
