hello,
when i want to import the ODK Collect project on Android studio, he told me that there's an error
how to repair it plz
Follow the read me at https://github.com/opendatakit/collect. You need
to checkout three projects before Collect will build.
On Fri, Oct 23, 2015 at 1:34 AM, Joey Starr bigbonic@gmail.com wrote:
hello,
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
when I tried to import code from github it gave me an error that
unsupported host "services.gradle.org" can you help please
hey Yaw please help me also man I am trying to import collect odk but it
is giving error can you explain me if anything else I have to do besides
creating a folder ODK and inside that folder creating a repository of
collect and then creating a repository of google play services and then
creating a repository of gradle config and after that importing the
collect/build.gradle in android studio tell me if anything I am missing
and do reply please I am in very much need of your help but when I am doing
all these things I am getting this error.
Thanks for the reply Yaw,
so i create one folder OKD with subfolder collect-master and playservices-bad-master, but what is the Gradle-config ? what should in the folder ?
Hi Vikas,
You've sent countless messages about this issue. This is annoying to
everyone on the list, so please stop.
We are all volunteers here, and so if and when someone has a
suggestion on how to fix your problem, I'm sure they will respond.
If this is an emergency, you can find paid help at
https://opendatakit.org/help/help-for-hire. If you can't hire help, I
suggest you find patience.
collect/build.gradle in android studio tell me if anything I am missing and
do reply please I am in very much need of your help but when I am doing all
these things I am getting this error.--
Hi Joey,
This is gradle-config: https://github.com/opendatakit/gradle-config/
It shouldn't be strictly necessary to have locally, but if you want it, it
should also be a subfolder of your ODK directory. Having a copy locally
allows you full control of the gradle build configuration.
Also, you want this version of play services:
The version you have is an artifact of our first, unsuccessful attempt to
migrate to Github.
Regards,
Jeff
folder ?--
