Importing xls to kobo
I exported XLS in order to trhy to set up repeat group of questions based on the previous response on of how many persons.
I am unsure if I placed the information in the correct row and column, and I also do not know how to import it back to test.
Help please
It will be great if you can share an excel sheet.
Narendra
hi @scherrie,
at first sight it looks correct but to test the syntax and form you can always do it here
Your form looks OK from what is visible in the photo.
You may want to check the Kobo support pages or community forum where questions about uploading XLSForms and using repeat_count have been answered.
