Inconsistency EnketoId between upload draft form return and draft for details
The return values when I upload a draft form via API and when I explicitly request form details are almost equal: enketoID is not available after upload, but present on form details request.
It is a minor point, but it would be good if these two were consistent.
Hi @dmenne! Is this when you create the form for the first time? The Enketo ID is generated asynchronously, which often takes a few seconds, so it won't exist at the time of the first response, but it might exist by the time you request form details.
Yes, it is on the first run, and while writing a test I noted that the return on creation and on the next query are different in enketoID.
I can understand that this is not a simple sequence problem when it is asynchronous. Never mind, it's a minor point relevant in testing only probably.
