Hi all,
I try to increase the string length to more than 255 for geotracing. I have created the attached xls file to convert it to xml with XLSForms. I read all the previous forum responses on how to increase string length, but for one way or another, it does not work. With the attached xls I get an error when I am trying to upload my xml (see attached xls file) file to Aggregate eventhough the xls is accepted and translated to xml by XLSForms without any problem. The error I get when I upload the xml to Aggregate is: "HTTP Status 400 - Problem with JavaRosa Parsing Form: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa failed to construct a FormDef. Is this an XForm definition?" I am using Aggregate v1.4.7. I am using mac.
I read all the previous discussions but I am a bit confused if I need to change things in the header of the xml files or not. Some discussions indicate yes, others not. Can anyone tell me what could be the problem? Is it my xls file, my xml file or an Aggregate problem? Aggregate seems to have problems with the binding: binding::odk:length. If I change this to e.g. binding::odk-length, Aggregate accepts it, but my text field is still truncated to 255 characters... Thanks for the feedback!
Hi, ggalmazor, is there a tool to transfer XLS files to XForms? I am an end-user, not a programmer. The issue that you are mentioning is completely new to me. I never worked with XForms.
Hi both, yes, I tranfered the xls file with XLSForms. Although I am an end-user, I am using ODK for several years now. So I know how the conversion process and uploading to aggregate works. However, I have a problem with the increasing string length. For one way or another, it does not work. Some (older) forum discussion mention that you have to change things in the xml header and some say you only have to create a column (bind::odk:lenght) and the binding odk:length="xxxx" (xxxx = e.g. 1000). Then convert it to xml with XLSForms. However, this does not work. So my question is: Is there something wrong with my xls form or with my Aggregate version or do I still have to change something in the xml header after I changes my xls to xml.?
There is way of doing that in xls. This instruction were available in the previous site
Datastore String Length¶
In ODK Aggregate 1.x, you can supply an attribute to the to specify the maximum number of characters used to store a string field; by default, the datastore layer limits strings to 255 characters or less. If a submission has data beyond this length, it is silently truncated upon submission.
Specifying a value less than 255 can significantly improve the storage efficiency of the database layer. You can also specify a value greater than 255, up to a maximum of about 16000 UTF-8 characters. The higher you set this value, the worse the storage efficiency within the datastore.
To set the string length:
Step 1: In the header of the form definition, add a xmlns alias for odk (shown added as the last xmlnsalias at the bottom of the <h:html> tag):
Hi ggalmazor, that was the trick! It worked. So what I did was:
create a column with bind::odk:length
add to the respective node for 'geotrace': odk:length="1000"
convert this to xml with XLSForms
open the xml with a text editor and remove the 'garbage' (it said something like: odk:length="blabla%1000" produced and cnahge this to odk:length="1000".
Save and close and upload it to aggregate.
Worked perfectly! Many thanks for the help! Also the other respondents for their effort. Thanks!
Step 1: Create a column in xls with "bind::odk-length" as a title
Step 2: For those text inputs specify the length ie 15999
Step 3: Convert the xls to xml
Step 4: Open the xml with a text editor such as notepad and change odk-length="15999" to odk:length="15999"
Step 5: Paste this to the form definition
Hi Samwel, many thanks for your help. Good for others to know this and that there are several ways to do it. This also clarify the differences in approach. I did read about your solution too in previous discussions (working with bind::odk-length), but was not aware that in that case you must enter just the number of characters (not odk:length="xxx" as I did). For end-users this may be confusing.
What you are posting about the way the XLS form should look like is correct. However, for clarity: I still needed to edit my xml after converting the XLS to XML. Without xml edit, it did not work in my case. As I described, it worked for me if I removed the 'blabla-code' in odk:length (the converted xml contained a lot of code such as: odk:length="blabla%8%1000"). I replaced this 'blabla-code' with a text editor to odk:length="1000" (to have for 1000 characters). I don't know if this has to do with an older version of Aggregate (which I am using), or you have to carry out an xml-edit also for the latest Aggregate...
By the way: I just did a search in my xml on "odk:length" to find all the entrances that need to be changed.
Did you only include the value (e.g. 1000) in the bind::odk:length column? Can you share exactly what showed up in the XML? If you can share your new form and new XML, that would be great. What converter are you using to go from XLSForm to XML (e.g. XLSForm online or offline)?
I found out that the off-line XLS converter that I purchased does not work (version 1.4.0) with bind:odk:length. So only the online converter works (https://opendatakit.org/xlsform/)
When I convert the XLS with this online converter and open the xml with a text editor, the following code appears in the xml form:ODK_form_geoshape.xml (60 Bytes)
For other readers: This code can appear multiple times in your xml, depending on the number of entrances that you entered bind:odk:length in your xls. You have to replace them all.
So I removed all this code and replaced it by odk:length="15999". Then saved it and it works.
@Eddy_Rellum That output makes it look like you're specifying odk:length="15999" in your XLSForm when you should be specifying just 15999. Can you please double check that? This post shows exactly what the column should look like.
If not, please paste the row in your XLSForm that specifies the length so we can try to reproduce.
That is correct. In the question row I put: odk:length="15999". See the attached excel that I used for the conversion to xml.ODK_form_test_geoshape.xlsx (20.1 KB)
