hi,
I have a form with a node like:
and I would like to add a hidden id (called person_id) which is filled
with the current value of "jr:count".
I've seen XForms doesn't support hidden values because "any values in
the instance that haven't been bound to by a control are by definition
not visible to the user".
but I don't see how could I use the jr:count value. I tried by using
the IDREF of the repeat node and calling it from the bindings:
but it didn't work. I tried also some other possibilities, but I'm not
even sure 'calculate' is fully supported by javarosa (it works in some
cases, although in the documentation it's said 'calculate' is not
supported).
Do you have any idea about how to create such 'hidden id' without
having to add an input method? I've seen ODK prints the iteration
number in a 'repeat' loop, but it seems it doesn't use the index
function, but some internal counter.
thanks in advance,
best,
pau.
hi pau,
i understand what you are asking but don't have an immediate response.
i've escalated to some xforms experts and i'll let you know when i
know...
yaw
On Tue, Jun 8, 2010 at 02:09, Pau Varela wrote:
> hi,
> jr:noAddRemove="true()" jr:count="/data/household/adults_missing"
> id="person-repeat">
> type="int" calculate="index('person-repeat')"/>
> supported).
> thanks in advance,
> best,
> pau.
Pau,
To clarify: Are you trying to access the current index of the repeat node?
IE: Filling out the id field in this sample template?
Clayton
1
2
We don't current support the xform function which returns the index of the
current repeat (because the function's contract requires the repeat to have
an XML ID, which is also currently unsupported).
We are going to expand the set of supported XPath expressions in a future
release of our core XForm library, but I'm not sure exactly when that will
be. It would be possible to write in this function into a custom version of
ODK which registered a function handler with the parser as advanced
behavior...
-Clayton
On Tue, Jun 8, 2010 at 9:37 AM, Yaw Anokwa wrote:
hi pau,
know...
yaw
On Tue, Jun 8, 2010 at 02:09, Pau Varela pau.varela@gmail.com wrote:
hi,
supported).
thanks in advance,
best,
pau.
Unsubscribe: opendatakit+unsubscribe@googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
hi Clayton and Yaw,
thanks for your replies. yes, access to the current index of the
repeat node is exactly what I would like to do.
My impression was it wasn't supported, but I wanted to verify it.
unfortunately, it seems I was right
I only have been working with XForms for a couple of months and
looking at the 'pure' XForms documentation, it seems that using the
node's IDREF (I understand it's the XML ID you mention) together with
the index() funtion is possible to access to this value. But after
trying it and reading javarosa documentation, I wasn't able to do it
and that's why I sent here my question. Now at least I know the
reason...
The project I'm working for (eMOCHA) is using already a modified
version of ODK.. when you say "It would be possible to write in this
function into a custom version of ODK which registered a function
handler with the parser as advanced behavior...", how do I register a
function handler? could you please give me some other hint or some
class names so I can take a look at the code?
thanks again,
pau.
2010/6/9 Clayton Sims :
> Pau,
> Clayton
> 1
> Yaw
> 2
> behavior...
> -Clayton
>> hi pau,
>> know...
>> yaw
>> > hi,
>> > id="person-repeat">
>> > supported).
>> > thanks in advance,
>> > best,
>> > pau.
Pau,
In the code there is a class which is created when a form entry model and
controller is generated called EvaluationContext which maintains the state
necessary to evaluate XPath expressions during form entry. This class allows
you to register IFunctionHandler's which can define new functions to be used
in XPath expressions.
Implementing a function to pull the index of the current repeat would
definitely be tricky, but I believe you could possibly do it with some
assumptions and hacking. You can see the function handling code at
http://www.bitbucket.org/javarosa/javarosa/src/tip/core/src/org/javarosa/xpath/expr/XPathFuncExpr.java
You probably want to get an argument as a XPathNodeset or the node itself
and do something like walk up its reference or tree structure until a repeat
is found, then look for its index.
-Clayton
On Wed, Jun 9, 2010 at 12:06 PM, Pau Varela wrote:
hi Clayton and Yaw,
reason...
thanks again,
pau.
2010/6/9 Clayton Sims csims@dimagi.com:
Pau,
node?
Clayton
1
2
the
have
will
of
behavior...
-Clayton
On Tue, Jun 8, 2010 at 9:37 AM, Yaw Anokwa yanokwa@gmail.com wrote:
hi pau,
know...
yaw
hi,
supported).
thanks in advance,
best,
pau.
hi Clayton,
thanks for the tip. I've been looking at the code and, as you said, it
seems not easy, but possible...
I understand I should define my own IFunctionHandler class, like the
org.odk.collect.android.RegexFunction and let XPathFuncExpr call its
methods when creating/editing the forms.
Since I don't see how to read, in run-time, the index of a repeat node
from its binding, I think I'll go for some dirty solution like storing
temporarily the number of created nodes and check it against the
numbers of node I have to create (the count number), in order to know
the next id. It is not nice, but I guess it will work. Otherwise I
think I should do a lot of hacking in ODK and maybe javarosa..
My last question would be if calling functions from the calculate
attribute is a supported feature. According to the doc
(http://code.javarosa.org/wiki/xform) it's not, but our forms contain
some calls to the "if" function defined in the XPathFuncExpr class
(e.g: calculate="if(/data/scheduled_fu_visit_date > today(), '1',
'0')") and they are working fine.
Anyway, I'll try and see
thanks again for your help
pau.
2010/6/11 Clayton Sims :
> Pau,
> -Clayton
>> hi Clayton and Yaw,
>> unfortunately, it seems I was right ;)
>> reason...
>> thanks again,
>> pau.
>> > Pau,
>> > node?
>> > Clayton
>> > 1
>> > Yaw
>> > 2
>> > the
>> > have
>> > future
>> > will
>> > of
>> > behavior...
>> > -Clayton
>> >> hi pau,
>> >> know...
>> >> yaw
>> >> > hi,
>> >> > id="person-repeat">
>> >> > filled
>> >> > definition
>> >> > not
>> >> > some
>> >> > supported).
>> >> > thanks in advance,
>> >> > best,
>> >> > pau.
Pau,
Calling functions from calculate is a supported feature, that doc is
slightly out of date, sorry.
Additionally, you should be able to get the index of a repeat node from its
treereference (or the treereference of a parent node which is the repeat).
-Clayton
On Mon, Jun 14, 2010 at 7:08 AM, Pau Varela wrote:
hi Clayton,
pau.
2010/6/11 Clayton Sims csims@dimagi.com:
Pau,
state
allows
used
repeat
-Clayton
On Wed, Jun 9, 2010 at 12:06 PM, Pau Varela pau.varela@gmail.com wrote:
hi Clayton and Yaw,
reason...
thanks again,
pau.
Pau,
node?
Clayton
1
2
the
have
future
will
version
of
behavior...
-Clayton
hi pau,
response.
know...
yaw
hi,
filled
in
definition
using
not
some
supported).
thanks in advance,
best,
pau.
hi Clayton,
I don't know whether it's an old behaviour (we are using an old ODK
version), but after implementing and testing a new function it looks
to me 'calculate' only evaluates the customized function when the form
is not deserialized.
in the FormLoaderTask class, there is a check to see whether the
binary version of the form exist in the cache directory (.formdef
files). If I manually remove the .formdef file from the device, my new
function is evaluated, but it is not when ODK finds the cached file.
There is anything I can do except for skipping the loading of the
cached files? Which would be the perfomance consequences of ignoring
those cached files?
thanks and regards,
pau.
2010/6/14 Clayton Sims :
> Pau,
> -Clayton
>> hi Clayton,
>> Anyway, I'll try and see ;)
>> pau.
>> > Pau,
>> > and
>> > state
>> > allows
>> > used
>> > itself
>> > repeat
>> > -Clayton
>> >> hi Clayton and Yaw,
>> >> reason...
>> >> thanks again,
>> >> pau.
>> >> > Pau,
>> >> > node?
>> >> > Clayton
>> >> > 1
>> >> > Yaw
>> >> > 2
>> >> > of
>> >> > the
>> >> > to
>> >> > have
>> >> > future
>> >> > will
>> >> > version
>> >> > of
>> >> > behavior...
>> >> > -Clayton
>> >> >> hi pau,
>> >> >> response.
>> >> >> know...
>> >> >> yaw
>> >> >> > hi,
>> >> >> > id="person-repeat">
>> >> >> > filled
>> >> >> > in
>> >> >> > definition
>> >> >> > using
>> >> >> > not
>> >> >> > some
>> >> >> > supported).
>> >> >> > thanks in advance,
>> >> >> > best,
>> >> >> > pau.
The cached files are built when a form is first processed and it
results in significant time savings when loading a form the second
time. Clayton, any ideas why the caching would kill calculate?
On Monday, June 21, 2010, Pau Varela wrote:
> hi Clayton,
> those cached files?
> thanks and regards,
> pau.
>> Pau,
>> -Clayton
>>> hi Clayton,
>>> pau.
>>> > Pau,
>>> > and
>>> > state
>>> > allows
>>> > used
>>> > itself
>>> > repeat
>>> > -Clayton
>>> >> hi Clayton and Yaw,
>>> >> reason...
>>> >> version of ODK--
In 1.1.2 could this be because line 82 in
FormLoaderTask class will only execute only when there is no cached
object. Could moving
it to line 90 solve it. Funny enough mine works as it is even for cached
forms.
--Sam
>> hi Clayton,
>> those cached files?
>> thanks and regards,
>> pau.
>> 2010/6/14 Clayton Sims:
>>> Pau,
>>> -Clayton
>>>> hi Clayton,
>>>> (e.g: calculate="if(/data/scheduled_fu_visit_date> today(), '1',
>>>> pau.
>>>> 2010/6/11 Clayton Sims:
>>>>> Pau,
>>>>> and
>>>>> state
>>>>> allows
>>>>> used
>>>>> itself
>>>>> repeat
>>>>> -Clayton
>>>>>> hi Clayton and Yaw,
>>>>>> reason...
>>>>>> version of ODK--
