Hello all,
I have a survey in which I need to put in a user ID which happens to be 10
digits long. My element is bound thus:
Nowhere in the above line do I limit the number of characters to 9, and I
need to be able to store 10 digits. What needs doing?
Thanks in advance,
Tumaini
Does anyone know why I cannot store more than 9 number characters in this
input widget? Is this a limitation? What happens when one needs to input a
number with more than 9 digits?
On Tue, Jun 12, 2012 at 12:30 PM, Tumaini Kilimba wrote:
Hello all,
Thanks in advance,
Tumaini
According to the notes in the ODK Collect code:
"// ints can only hold 2,147,483,648. we allow 999,999,999"
The 9 digit limit appears to prevent people from putting too large of
number in the input. Because of historical computer design reasons an
Integer in Java must be smaller than 2,147,483,648. There are
different number types that can support larger values but that will
require a lot of changes.
May I suggest using a string instead?
If you would like this changed feel free to file an issue on the
website but it will unlikely happen quickly because I believe it will
require changes to JavaRosa.
Cheers,
Waylon
>> Hello all,
>> > relevant="selected(/data/participantId, '')" />
>> Thanks in advance,
>> Tumaini
Thanks Waylon, I will use a string instead
Cheers,
Waylon
this
a
On Tue, Jun 12, 2012 at 12:30 PM, Tumaini Kilimba tkilimba@ihi.or.tz wrote:
Hello all,
10
I
Thanks in advance,
Tumaini
You can use a string with a appearance="number" and it will let you only
input numbers, but up to the length of a string.
Cheers,
Waylon
this
input a
Hello all,
be 10
and I
Thanks in advance,
Tumaini
Brilliant! Just what I needed!
Cheers,
Waylon
this
input a
Hello all,
be 10
and I
Thanks in advance,
Tumaini
mhhhhhh.... it seems that having the attribute appearance="number" does not
make the slightest bit of difference, the keyboard still defaults to
inputting letters and not numbers. Any suggestions?
Tumaini
>>> Cheers,
>>> Waylon
>>> this
>>> input a
>>> >> Hello all,
>>> be 10
>>> and I
>>> >> Thanks in advance,
>>> >> Tumaini
Tumaini,
Try appearance="numbers" (with an s on the end), as in the example on
http://opendatakit.org/help/form-design/examples/.
There was also a bug in the numbers implementation a few months back, but
it was fixed in the Collect v1.1.7 in Android Market and also in the
v1.2RC. So just make sure that you're running a fairly modern version of
Collect.
Chris
not make the slightest bit of difference, the keyboard still defaults to
Tumaini
Cheers,
Waylon
this
a
Hello all,
10
I
Thanks in advance,
Tumaini
Unsubscribe: opendatakit+unsubscribe@**googlegroups.com
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
