Is there an easy way to insert a variable in the begining or middle of a
large form? The only way I know of is to insert at the end of the form
and then move them up but it is such a pain when you work with a large form.
Wen
That's one reason we recommend XLSForm for larger surveys.
It is much easier to rearrange and modify the survey when it is an Excel
worksheet.
On Thu, Jul 30, 2015 at 4:30 PM, Wen wrote:Is there an easy way to insert a variable in the begining or middle of a
Wen--
Thanks for the reply
