Installation problem odk aggregate - ssl/security error
ODK aggregate v1.5
Ubuntu 18.04 on Dell xps 13
The script is unable to open the browser for giving permission to odk aggregate to access the google app engine. The dialog for entering code opens directly.
When the url is manually entered in the browser and the code pasted in the dialog that has opened up 'ODK aggregate updater' throws the error "javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty"
Have tried multiple times to get the token code right. Same error repeats.
/home/christy/Pictures/Screenshot from 2018-06-11 21-35-45.png
Hi @Christy! This likely an Ubuntu 18.04 issue and you can find a workaround here:
Thank you Yaw Anokwa. After getting the ca-certificates updated installation went on smooth.
