Hi!
Just try if anyone has a workaround with my problem here.
I'm installing ODK Aggregate using cloud server. I was able to install java, tomcat and mysql.
I followed all the steps in the instruction I got from here http://itinformation-shyam.blogspot.co.za/2015/04/how-to-install-and-configure-odk.html
But i still get Apache error when I'm trying to access the aggregate.
HTTP Status 404 -
type Status report
message
description The requested resource () is not available.
Apache Tomcat/6.0.24
Upon looking on the catalina.out file it seems tomcat have an issue on communicating with mysql.
Here are the info of my server
-> Red Hat 4.4.7-18
-> OpenJDK Runtime Environment (rhel-2.6.9.0.el6_8-x86_64 u131-b00)
-> OpenJDK 64-Bit Server VM (build 24.131-b00, mixed mode)
-> tomcat 6
Here's the content of log
Apr 26, 2017 10:26:17 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Apr 26, 2017 10:26:17 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Apr 26, 2017 10:26:17 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 783 ms
Apr 26, 2017 10:26:17 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Apr 26, 2017 10:26:17 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.24
Apr 26, 2017 10:26:17 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor ROOT.xml
Apr 26, 2017 10:26:17 AM org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/usr/share/tomcat6/webapps/ROOT/WEB-INF/lib/servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
Apr 26, 2017 10:26:18 AM org.apache.catalina.core.ApplicationContext log
INFO: Initializing Spring root WebApplicationContext
log4j:WARN No appenders could be found for logger (org.springframework.web.context.ContextLoader).
log4j:WARN Please initialize the log4j system properly.
Inside setServletContextafterPropertiesSet WATCHDOG TASK IN TOMCAT
Apr 26, 2017 10:26:20 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hierarchicalRoleRelationships' defined in ServletContext resource [/WEB-INF/applicationContext-security.xml]: Invocation of init method failed; nested exception is org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [CREATE TABLE odk_prod._granted_authority_hierarchy ( _URI VARCHAR(80) CHARACTER SET utf8 NOT NULL , _CREATOR_URI_USER VARCHAR(80) CHARACTER SET utf8 NOT NULL , _CREATION_DATE DATETIME(6) NOT NULL , _LAST_UPDATE_URI_USER VARCHAR(80) CHARACTER SET utf8 NULL , _LAST_UPDATE_DATE DATETIME(6) NOT NULL , DOMINATING_GRANTED_AUTHORITY VARCHAR(80) CHARACTER SET utf8 NOT NULL , SUBORDINATE_GRANTED_AUTHORITY VARCHAR(80) CHARACTER SET utf8 NOT NULL , INDEX(_URI ) USING HASH , INDEX(_LAST_UPDATE_DATE ) , INDEX(DOMINATING_GRANTED_AUTHORITY ) USING HASH ) ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(6) NOT NULL , _LAST_UPDATE_URI_USER VARCHAR(80) CHARACTER SET utf8 NULL , _L' at line 1 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1583) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:754) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:866) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4244) at org.apache.catalina.core.StandardContext.start(StandardContext.java:4743) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526) at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637) at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1277) at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:321) at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053) at org.apache.catalina.core.StandardHost.start(StandardHost.java:722) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045) at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443) at org.apache.catalina.core.StandardService.start(StandardService.java:516) at org.apache.catalina.core.StandardServer.start(StandardServer.java:710) at org.apache.catalina.startup.Catalina.start(Catalina.java:593) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414) Caused by: org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [CREATE TABLE odk_prod._granted_authority_hierarchy(_URIVARCHAR(80) CHARACTER SET utf8 NOT NULL ,_CREATOR_URI_USERVARCHAR(80) CHARACTER SET utf8 NOT NULL ,_CREATION_DATEDATETIME(6) NOT NULL ,_LAST_UPDATE_URI_USERVARCHAR(80) CHARACTER SET utf8 NULL ,_LAST_UPDATE_DATEDATETIME(6) NOT NULL ,DOMINATING_GRANTED_AUTHORITYVARCHAR(80) CHARACTER SET utf8 NOT NULL ,SUBORDINATE_GRANTED_AUTHORITY VARCHAR(80) CHARACTER SET utf8 NOT NULL , INDEX(_URI ) USING HASH , INDEX(_LAST_UPDATE_DATE ) , INDEX(DOMINATING_GRANTED_AUTHORITY) USING HASH ) ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(6) NOT NULL ,_LAST_UPDATE_URI_USERVARCHAR(80) CHARACTER SET utf8 NULL ,_L' at line 1
at org.opendatakit.common.persistence.engine.mysql.DatastoreImpl.assertRelation(DatastoreImpl.java:751)
at org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable.assertRelation(GrantedAuthorityHierarchyTable.java:115)
at org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable.getEntireGrantedAuthorityHierarchy(GrantedAuthorityHierarchyTable.java:186)
at org.opendatakit.common.security.spring.RoleHierarchyImpl.buildRolesReachableInOneStepMap(RoleHierarchyImpl.java:464)
at org.opendatakit.common.security.spring.RoleHierarchyImpl.refreshReachableGrantedAuthorities(RoleHierarchyImpl.java:281)
at org.opendatakit.common.security.spring.RoleHierarchyImpl.afterPropertiesSet(RoleHierarchyImpl.java:132)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1642)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1579)
... 36 more
Caused by: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [CREATE TABLE odk_prod._granted_authority_hierarchy ( _URI VARCHAR(80) CHARACTER SET utf8 NOT NULL , _CREATOR_URI_USER VARCHAR(80) CHARACTER SET utf8 NOT NULL , _CREATION_DATE DATETIME(6) NOT NULL , _LAST_UPDATE_URI_USER VARCHAR(80) CHARACTER SET utf8 NULL , _LAST_UPDATE_DATE DATETIME(6) NOT NULL , DOMINATING_GRANTED_AUTHORITY VARCHAR(80) CHARACTER SET utf8 NOT NULL , SUBORDINATE_GRANTED_AUTHORITY VARCHAR(80) CHARACTER SET utf8 NOT NULL , INDEX(_URI ) USING HASH , INDEX(_LAST_UPDATE_DATE ) , INDEX(DOMINATING_GRANTED_AUTHORITY ) USING HASH ) ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(6) NOT NULL , _LAST_UPDATE_URI_USER VARCHAR(80) CHARACTER SET utf8 NULL , _L' at line 1 at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:231) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:73) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:419) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:443) at org.opendatakit.common.persistence.engine.mysql.DatastoreImpl.assertRelation(DatastoreImpl.java:737) ... 43 more Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(6) NOT NULL , _LAST_UPDATE_URI_USERVARCHAR(80) CHARACTER SET utf8 NULL ,_L' at line 1
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:377)
at com.mysql.jdbc.Util.getInstance(Util.java:360)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:978)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3887)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3823)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2435)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2582)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2526)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2484)
at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:848)
at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:742)
at org.apache.commons.dbcp2.DelegatingStatement.execute(DelegatingStatement.java:291)
at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:435)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:408)
... 45 more
Apr 26, 2017 10:26:20 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context startup failed due to previous errors
Apr 26, 2017 10:26:20 AM org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
Apr 26, 2017 10:26:20 AM org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
SEVERE: A web application registered the JBDC driver [com.google.appengine.api.rdbms.AppEngineDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
SEVERE: A web application registered the JBDC driver [org.postgresql.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
Apr 26, 2017 10:26:20 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SEVERE: A web application appears to have started a thread named [Abandoned connection cleanup thread] but has failed to stop it. This is very likely to create a memory leak.
Apr 26, 2017 10:26:20 AM org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap
SEVERE: A web application created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Prototype beans currently in creation]) and a value of type [null] (value [null]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
SEVERE: A web application created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Current transaction name]) and a value of type [null] (value [null]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
SEVERE: A web application created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Current transaction read-only status]) and a value of type [null] (value [null]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
SEVERE: A web application created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Current transaction isolation level]) and a value of type [null] (value [null]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
SEVERE: A web application created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Transactional resources]) and a value of type [null] (value [null]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
SEVERE: A web application created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Actual transaction active]) and a value of type [null] (value [null]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
Apr 26, 2017 10:26:21 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Apr 26, 2017 10:26:21 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Apr 26, 2017 10:26:21 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/28 config=null
Apr 26, 2017 10:26:21 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 4222 ms
