i'm trying to install ODK but it fails when i want to upload it to the Google App Engine Instance. I copied and pasted the code generated with my email for the Google account's authorization web page. i obtained the following message below:
listBackends!: juil. 25, 2017 11:46:15 AM com.google.appengine.tools.info.RemoteVersionFactory getVersion
listBackends!: INFOS: Unable to access https://appengine.google.com/api/updatecheck?runtime=java&release=1.9.54×tamp=1496703369&api_versions=['1.0']
listBackends!: java.net.ConnectException: Connection timed out: connect
listBackends!: at java.net.DualStackPlainSocketImpl.connect0(Native Method)
listBackends!: at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
listBackends!: at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
listBackends!: at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
listBackends!: at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
listBackends!: at java.net.PlainSocketImpl.connect(Unknown Source)
listBackends!: at java.net.SocksSocketImpl.connect(Unknown Source)
listBackends!: at java.net.Socket.connect(Unknown Source)
listBackends!: at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
listBackends!: at sun.security.ssl.BaseSSLSocketImpl.connect(Unknown Source)
listBackends!: at sun.net.NetworkClient.doConnect(Unknown Source)
listBackends!: at sun.net.www.http.HttpClient.openServer(Unknown Source)
listBackends!: at sun.net.www.protocol.https.HttpsClient.(Unknown Source)
listBackends!: at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
listBackends!: at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
listBackends!: at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
listBackends!: at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
listBackends!: at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
listBackends!: at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
listBackends!: at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
listBackends!: at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
listBackends!: at java.net.URL.openStream(Unknown Source)
listBackends!: at com.google.appengine.tools.info.RemoteVersionFactory.getVersion(RemoteVersionFactory.java:76)
listBackends!: at com.google.appengine.tools.info.UpdateCheck.getApplicationVersionInfo(UpdateCheck.java:152)
listBackends!: at com.google.appengine.tools.info.UpdateCheck.maybePrintNagScreen(UpdateCheck.java:360)
listBackends!: at com.google.appengine.tools.admin.AppCfg.(AppCfg.java:177)
listBackends!: at com.google.appengine.tools.admin.AppCfg.(AppCfg.java:116)
listBackends!: at com.google.appengine.tools.admin.AppCfg.main(AppCfg.java:112)
listBackends!:
listBackends : The following URL can be used to authenticate:
listBackends : https://accounts.google.com/o/oauth2/auth?access_type=offline&approval_prompt=force&client_id=550516889912.apps.googleusercontent.com&redirect_uri=urn:ietf:wg:oauth:2.0:oob&response_type=code&scope=https://www.googleapis.com/auth/appengine.admin%20https://www.googleapis.com/auth/cloud-platform
listBackends : Attempting to open it in your browser now.
listBackends : Please enter code:
listBackends!: java.net.SocketException: Connection reset
listBackends!:
listBackends :
status : Action failed or aborted by user
ODK Aggregate v1.4.15 windows-installer.exe
I've installed the last java version (build 1.8.0_141-b15)
