But I couldn't access to the ODK server page using web browser.
you may test using the URL below:
18.216.143.32:8080/
During the installation of ODK Aggregate, I specify the elastic IP Address of AWS EC2 instance which the tomcat and mysql installation would be.
I'm using Tomcat8, mysql 5.5.58
Basically follow the guide to install ODK Aggregate into AWS Cloud.
I also did rename the ODKAggregate.WAR to ROOT.war
so that the url would be :
18.216.143.32:8080/
and also tried without rename, and the url tested is :
18.216.143.32:8080/ODKAggregate
I even tried re-install ODK Aggregate and follow the guide again also doesn't solve the problem accessing the main page of ODK form.
El procedimiento de la guia obliga que uses certificados. Si no quieres usar HTTPS (no lo recomiendo), entonces tendras que desinstalar certbot y cambiar la configuracion de nginx y Aggregate. Lamento no poder darte instrucciones mucho mas precisas. Espero que las guia que tenemos te sirvan de ayuda:
I tried using AWS but I have many inconveniences. Help me to install it on Digital. Do You have some video on how to do it?
Lamentablemente, no hay ningun video (que sepamos) sobre la instalacion en Digital Ocean, pero la guia de https://docs.opendatakit.org/aggregate-digital-ocean/ deberia ayudarte a ponerlo en marcha. La has probado? Deberias poder montar tu servidor con ella y si te animas, tambien puedes grabarlo en video para el resto de la comunidad
