Instances Not Seen
Dear all,
I have saved and finalized the form and the data is seen when I browse it
on the tablet but when i hook my tablet on the computer and want to use odk
briefcase I cant see the instances.
On the tablet all the data is there and i can browse through all the data
but i cant pull data using briefcase and i also i cant see the actual
instances in the instances folder when i hook it my computer.
Please help.
Rod
This is normal.
The "File Explorer" access to files on the phone is bad. Very very bad.
The best solution is to zip up the odk folder on the device, then copy that
zip to the computer.
See https://opendatakit.org/use/briefcase/#Pull_4.x
··· On Mon, Aug 3, 2015 at 12:23 PM, Rod wrote:
Dear all,
Please help.
Rod
