Not in ODK Collect. You would need to first ask whether the respondent can
provide their 12-month rental income, and then ask (on a separate screen),
what that income was (if they are willing to provide the amount).
Also, note that all select-one and select-multiple values are all strings.
XLSForm.org has support for select-with-other prompts, and those are
available in Enketo and several other tools, but there are difficulties
with providing this within ODK Collect.
On Fri, Feb 19, 2016 at 9:11 PM, wrote:
Dear All,
I am trying to build in an integer reply into a single selection question.
Example below:
How much did you earn from rental in the last 12 months?
Selection 1: No income
Selection 2: Refused to answer
Selection 3: *String field to put answer *
