How can I set integer value to take more than nine digits?
See https://groups.google.com/d/msg/opendatakit/l4mwbraaXSM/AxMeEvXiGFcJ
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Fri, Apr 18, 2014 at 2:38 PM, Me metronomeconsults@gmail.com wrote:
Hi Muyiwa
Set the data type to 'text', set the appearance to 'numbers' and then add a constraint in the constraint column.
On Saturday, April 19, 2014 12:38:41 AM UTC+3, Muyiwa Agunbiade wrote: > How can I set integer value to take more than nine digits?Thank you for this
ME
On 27 April 2014 01:32, wrote:On Saturday, April 19, 2014 12:38:41 AM UTC+3, Muyiwa Agunbiade wrote:
Hi Muyiwa
a constraint in the constraint column.--
https://groups.google.com/d/topic/opendatakit/i-ZwqpyssdU/unsubscribe.
Muyiwa Agunbiade, PhD
Managing Partner
Metronome-CS Ltd.
Plot 41 Algiers Street,
Suite 301 Copper House Wuse Zone 5
Abuja - FCT, 900285
muyiwa.a@metronomeconsults.com muyiwa.a@metronomeconsults.com
www.metronomeconsults.com http://www.metronomeconsults.com/
Gracias Leah, me sirvió también lo del integer.
Tengo una pregunta, No hay otro tipo de dato númerico parecido al integer, por ejemplo el Long que es más largo, que permita introducir sólo números mayores a 9 dígitos.
Gracias.
Hola Leah.
Si establezo mi tipo de dato en "texto" cuantos dígitos puedo ingresar máximo.
Gracias
Hi @Jormer_Bermudez,
With text data type you can enter many more digits as required.
See the docs of how you can do that and understanding the limit if you are using aggregate server.
Muchas gracias Dicksonsamwel.
A post was split to a new topic: What programming language is Central in?
