I am using ODK Aggregate ODK Aggregate v2.0.5 on my windows server 2019, everything working fine, but when i am using Enketo API, for using webform feature, it will shown error message "ërror occurred during loading of this form. Unexpected token < in JSON at position 0 "
i am using ODK Collect app v1.30.1 for data collection and operating system android.
i trying my best ways to solve it.
Help me early to resolve this. 5. Anything else we should know or have? If you have a test form or screenshots or logs, attach below.
yes screen shot attached.
Just for clarity, do you have a Matrix question where you have a varibale name JSON either in one of the rows or columns? If so revise that column or row name and make sure it contains the underscore if there are two separate words. Sometimes the underscore automatically comes when you want to put space.
Then view the form ,if the error has been successfully corrected the view should be able to load questions,if not you will see an error specifyng the position of the error like your reference.
Please note that Aggregate is no longer being supported. Central has Enketo integrated as part of the standard installation. The post below has for more details about the end-of-life for Aggregate.
