Guys,
We want to transfer data collected to our ERP software. We are currently using ERP next. Is there anyone who has worked on such integration. I am new to programming but has worked as a product manager. I am doing this as a pilot for not for profit enterprise. So I am would require a lot of help on this.
One way I thought of is
Since the data captured is not dynamic. I will get the data in csv format on my email and upload it on ERP next.
Please let me know if someone can help. I am ready to grind here to get this completed.
Deepak
If your ERP has csv-import capabilities, you have two options:
(1) write a script that you can schedule (e.g., using cron (crontab) or
Windows Task Scheduler ) to run periodically.
The script runs ODK Briefcase via its command line interface to pull data
down from ODK Aggregate then
publishes that data to a csv that is then uploaded to the ERP.
(2) set up a publisher to Fusion Tables to Google Sheets. Then use either a
scheduled periodic script or use trigger events on those two services to
publish the data into your ERP via the Google app script mechanisms (
https://developers.google.com/apps-script/guides/triggers/events )
and ( https://developers.google.com/apps-script/advanced/fusion-tables )
#2 could also be used if the ERP has something other than csv-import.
On Tue, Mar 21, 2017 at 1:16 AM, wrote:
Guys,
on this.
this completed.
Deepak
"ODK Developers" group.
