By design, you cannot change data in ODK Aggregate.
That is correct. You correct AFTER exporting the data. Aggregate is meant
to be a repository "of record" that will hold originally submitted data so
that you can always go back to the original.
On Sat, Feb 11, 2012 at 4:57 PM, Yaw Anokwa wrote:By design, you cannot change data in ODK Aggregate.
On Sat, Feb 11, 2012 at 12:58, Zaher AL MUJAHEDIN zaher.almujahedin@gmail.com wrote:
Hello.
I have small errors like typing or spelling errors in the submissions
that i receive. Mostly misspelling of scientific names of specimens. We are
doing a research concerning the wildlife affected by the wave of cold
weather in our region. My question is how can I correct these errors before
I export the data ?Thank you.
Hi
I had the same problem some weeks ago, that i suggest is to edit the data
in the notepad++ before exporting to aggregate.
I did not have any probblem due this procedure, actually it was possible to
correct some typing mistakes
Bests
Em 11/02/2012 22:57, "Yaw Anokwa" escreveu:By design, you cannot change data in ODK Aggregate.
Hello.
Please can you share example how you done that using notepad++
