I need to translate ODK Collect into Spanish (and customize texts for a
very particular use, that's why I don't look for already existing
translations).
I've noticed that all the strings are in the strings.xml file, so I
already know how to edit it to replace the english texts with my custom
spanish texts.
Now my question is, is it already prepared somehow for having multiple
languages that the user can choose perhaps in the settings? At first
sight it looks like it isn't (that is, looks like I'll have to export
multiple versions of the app in different language and have the users
choose which one to install, which is pretty acceptable for my setup).
But I'm wondering if there is some mechanism that is already there,
already implemented, that I just don't know about, where I only need to
somehow add just another xml with the strings in another language??
Or am I dreaming?
I ask because I've seen there's a string called "change_language" but I
don't see any such option in the settings...
m.
Just to clarify, I meant multiple languages in the user interface, not
in the forms.
Oh I see, the "change language" is for changing the language of the
form, right?
So I guess the answer to my original question is no, multiple-language
user interface is not possible at the moment, �right?
thanks
m.
Matteo,
Multiple languages are possible in the interface. If you make a second (or
more) strings.xml file called strings-[language code].xml and add that to
the project, when you select Spanish as a language on your phone-settings
the application will use that language pack instead for the interface.
The form-language setting is separate.
If you do this, please send us the new strings.xml file and we'll add it to
the project.
Carl
On Mon, Oct 24, 2011 at 7:37 AM, Matteo Sisti Sette < matteosistisette@gmail.com> wrote:
Just to clarify, I meant multiple languages in the user interface, not in
the forms.
Oh I see, the "change language" is for changing the language of the form,
right?
So I guess the answer to my original question is no, multiple-language user
interface is not possible at the moment, ¿right?
thanks
m.
Mateo,
Have you tried changing the language setting on your phone?
Menu >> Settings >> Language and Keyboard>> Language
~Neil
On Mon, Oct 24, 2011 at 10:37 AM, Matteo Sisti Sette < matteosistisette@gmail.com> wrote:
the forms.
right?
thanks
m.
I just tried Collect 1.1.7RC2 on a phone using French for the general
Android interface. The ODK Collect was in English. Thus I guess no one has
translated it to french yet. I'd love to do that but I don't feel confident
to go into the development code and search out a translation file. Can
someone send it to me and then I can do the translation and send it back to
get re-integrated into the main branch.
Curtis Broderick
On Mon, Oct 24, 2011 at 5:42 PM, Carl Hartung wrote:
Matteo,
the project.
Carl
the forms.
right?
user interface is not possible at the moment, ¿right?
thanks
m.
Curtis BRODERICK
Responsable des supports clients
Tél : + 33(0)1.53.02.40.61
Health Information System
-----------------------www.epiconcept.fr------------------------
Ce message et toutes les pièces jointes sont établis à l'intention
exclusive de ses destinataires et sont confidentiels.
Si vous recevez ce message par erreur, merci de le détruire et d'en
avertir l'expéditeur.
The information contained in the Email and any attachments is
confidential and intended solely and for the attention and use of the
named address(es). It may not be disclosed to any other person without
the express authority of EpiConcept, or the intended recipient, or
both.
If you are not the intended recipient, you must not disclose, copy,
distribute or retain this message or any part of it.
I tried that, but then I get hundreds of compile error, basically
telling me for each and every string in the xml that it has a
duplicate definition.
I guess I'm missing some parameter/attribute in the xmls (hopefully
not on EACH string)...
2011/10/24 Carl Hartung :
> Matteo,
Matteo Sisti Sette
http://www.matteosistisette.com
the project.
Oh sorry, I'd love to, but apart from translating it, I'm also
customizing the texts to our particular scenario, where odk is used
actually to send "messages" rather than answer surveys. So for example
a saved form is called a "message" and a new form is called a
"template" and even more strange things. My translation wouldn't be of
much use to anybody else...
Here's how to do localization in Android applications:
http://developer.android.com/guide/topics/resources/localization.html#creating-alternatives
On Mon, Oct 24, 2011 at 3:23 PM, matteo sisti sette < matteosistisette@gmail.com> wrote:
2011/10/24 Carl Hartung carlhartung@gmail.com:
Matteo,
(or
Matteo Sisti Sette
I think there's no translation to any language included in the current release.
Matteo Sisti Sette
Ahh, ok, it's the folder values-[language code]/ not the file
m.
2011/10/25 Carl Hartung :
>> > Matteo,
>> > (or
>> > to
>> > phone-settings
>> Matteo Sisti Sette
Matteo Sisti Sette
