Dear Support,
We are facing issue installing Odk central on our ubuntu20 server with the given link: https://docs.getodk.org/central-install-digital-ocean/ .
Once we have tried to install odk under /data/ directory the application is not working, seems like getting some docker issue.
.But,
Now we have installed odk central /root/ directory then application is working fine .
Could you please let us know its compulsory to install Odk central only /root.
Thanks in advance.
You don't have to install in /root, but you do have to make sure the installing user account has the necessary permissions to install wherever you choose.
You'll have problems installing in /data/ because Central uses /data/transfer to move files between the container and the host..
Thanks master for your response.
How can we remove the odk central completely including docker? As we want to install it under /data/central directory not under /root/.
Note: we are using EC2 instance and we installed docker and compare separately.
To uninstall Docker entirely, see https://docs.docker.com/engine/install/ubuntu/#uninstall-docker-engine.
We do not recommend you install Central in /data/. Technically it is possible if you remap the '/data/transfer` folder mentioned above, but that's a deviation we have not tested.
And to be explicit, if you can't solve these kinds of issues on your own, self-hosting Central for a real project is not a good idea.
Thanks Master. Do you have any suggestion to host Central ?
I will say that AWS is one of the best options for the self-hosted ODK Central. But you should have some technical understanding of the linux.
Hello @iamnarendrasingh thanks for your suggestions.
