I am using ODK collect for collecting data. It was working fine in many surveys. Currently, in 2 Tabs, I am facing the issue of Not Found (404), i have tried all the troubleshooting suggested in forums. Now, I have tried using ODK BRIEFCASE for getting forms from mobile through PULL., but the forms are not showing for pulling. In both cases, I am unable to get forms out of mobile. Forms are important to get out to excel. Kindly help me to solve this issue.
1.2
I have tried using ODK BRIEFCASE and suggested measures from forum Anything else we should know or have? If you have a test form or screenshots or logs, attach here.
I see the error while Sending the forms to the server from "SEND FINALIZED FORMS". I use kobocollect as a backend server (https://kobo.humanitarianresponse.info/). It was working well on many projects, and working good with few projects. In the same projects also I am able to upload forms from 12 TABs, the issue came with only 2 TABs
By seeing the issues, I used ODK Briefcase to pull and export to the laptop as CSV. After browsing ODK folder, I am not seeing any forms to pull to Briefcase. The same method working for another tab, which I used for testing.
