Hi, dear all
when installing ODK Aggregate VM on windows PC, I met an issue which's
solution requires configuring port forwarding on the local computer to
enable external connections to it (in the case where the VM is on a NetWork
which does'nt assign it an IP); but, I don't know how to perform this
configuration.
In advance, thanks for your help.
Best
Please post only once for a given question. This list is moderated, which
can delay your posts.
This may require changing the configuration files within the VM image.
Those configuration files are described here:
You will likely need to hire someone who understands networks to determine
what changes are required. We have some information on network
configuration for Tomcat installs here:
https://opendatakit.org/use/aggregate/tomcat-install/#Configure_for_Network_Access
On Mon, Jul 18, 2016 at 6:27 AM, Amal wrote:Hi, dear all
configuration.
Best--
Thanks, Mitch.
sorry for those two posts; but it is because the first one was not
completed and sended by error.
Best
