Hello - I have been unable to use XLSForms to convert the attached form because of an issue in "calculate" when I try to generate a random number for a spot check. I receive the following error:
Error: ODK Validate Errors:
org.javarosa.xform.parse.XFormParseException: Invalid calculate for the bind attached to "${factor}" : Unexpected beginning of path in expression ${entries} /16
It would be wonderful if someone could take a look and let me know what I'm doing wrong. Thank you!
jessica
KE005DataEntryReport_v2.xls (162 KB)
Correct. The numeric division operator is "div".
This is because XPath expressions are used to reference fields in your
forms; when you type ${foo} the XLSForm converter converts that into an
XPath expression. While the XLSForm expands these with a leading slash,
they could also be expanded using ./ or ../ as a prefix. If the division
operator were allowed to be "/", and spaces were optional (like in most
numeric expressions), then if you wrote this expression:
${numerator}/${denominator}
a valid XLSForm conversion might be: ../numerator/../denominator
which resolves to a valid XPath expression for ../denominator
Because of this confusion, numeric division needed a new operator, "div".
On Wed, Dec 3, 2014 at 11:53 PM, Koassi AKAKPO akakpo.koassi@gmail.com wrote:
Hi
use ${entries} div 16
Koassi
${entries} /16
jessica
