Dear friends,
I found an issue with compact-3 function, please help me, if you have any
idea how can I overcome that! Under select one, I am using two options with
two images and after selecting one image when I clicked on another image
that selects too! It should act as radio buttons. Your suggestions will be
appreciated.
Imran
Hi Imran,
This sounds like a bug so please file it at
https://github.com/opendatakit/collect/issues/new.
Please include the version you are currently using. If compact-3
worked with an earlier version, also note that version number as well.
Finally, include a sample form that shows the problem.
On Wed, Apr 5, 2017 at 9:49 PM, A.N.M AL-IMRAN wrote:
> Dear friends,
> appreciated.
> Thanks,
> Imran
> "ODK Community" group.
Dear Yaw,
Thanks for your prompt response and sorry for my end for a delayed
response. Please find attached a sample form, on which there are three
compact functions: "quickcompact" which is working perfectly, "compact-2"
which I really need due to the type of the project I am working on, and I
am trying to use "compact-2" with select multiple and issue with this is,
if I select 3 options from the list and later if I want to deselect one, it
doesn't work. And Problem with "compact-3", I am trying to use that with
select_one question; however, I can select both of them. Please find
attached the sample form and image files to test the form.
Thank you once again.
Imran
sample_reporting_form.xml (3.79 KB)
sample_reporting_form.xlsx (13.2 KB)
image.zip (429 KB)
On Friday, April 14, 2017 at 12:41:29 AM UTC-4, Yaw Anokwa wrote:
> Hi Imran,
> Thanks,
> Yaw
> On Wed, Apr 5, 2017 at 9:49 PM, A.N.M AL-IMRAN <imra...@gmail.com > wrote:
> > Dear friends,
> any
> with
> be
> > appreciated.
> > Thanks,
> > Imran
> Groups
> an
Hi Imran,
Looks like the issue has been filed at
https://github.com/opendatakit/collect/issues/956 so we'll resond
there.
On Sat, Apr 22, 2017 at 8:50 AM, A.N.M AL-IMRAN wrote:
> Dear Yaw,
> Thanks for your prompt response and sorry for my end for a delayed response.
> Please find attached a sample form, on which there are three compact
> functions: "quickcompact" which is working perfectly, "compact-2" which I
> really need due to the type of the project I am working on, and I am trying
> to use "compact-2" with select multiple and issue with this is, if I select
> 3 options from the list and later if I want to deselect one, it doesn't
> work. And Problem with "compact-3", I am trying to use that with select_one
> question; however, I can select both of them. Please find attached the
> Imran
>> Hi Imran,
>> Thanks,
>> Yaw
>> > Dear friends,
>> > any
>> > with
>> > be
>> > appreciated.
>> > Thanks,
>> > Imran
>> > Groups
>> > an
>> > email to opendatakit...@googlegroups.com.
Dear Yaw,
Thanks and sorry for posting it here initially.
Regards,
Imran
A N M AL IMRAN (Imran)
Brossard, QC
Canada
Cell: +1 (438) 501 3576
On 24 April 2017 at 11:17, Yaw Anokwa wrote:
Hi Imran,
there.
On Sat, Apr 22, 2017 at 8:50 AM, A.N.M AL-IMRAN imran3may@gmail.com wrote:
Dear Yaw,
response.
trying
select
select_one
Imran
Hi Imran,
On Wed, Apr 5, 2017 at 9:49 PM, A.N.M AL-IMRAN imra...@gmail.com wrote:
Dear friends,
any
with
will
be
appreciated.
Imran
Groups
an
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/opendatakit/iVAlMW3TBDU/unsubscribe.
