Dear all,
I have an issue with ODK Collect rev1045.
- I can't do the cascading with the external itemset (the form as the
attached)
- After deleting the form with external itemset, I get new form with that
form again. Collect can't read the form & crash after then. I think the
issue could be itemset db since metadata is not deleted after deleting the
form.
Thanks & best regards,
Thu Le Anh
allinone.xml (76.2 KB)
itemsets.csv (46.6 KB)
Hi Thu Le Anh,
You were correct that the metadata associated with an external itemset
wasn't being deleted properly using the delete form option in Collect. I
just checked in a fix for the problem.
Until a new version is pushed to market, you can avoid a crash by making
any change to your itemset.csv file and reloading your form. The metadata
update was working properly, just not the delete.
-Carl
On Wed, Sep 24, 2014 at 3:00 AM, Thu Le Anh wrote:
Dear all,
attached)
form.
Thu Le Anh
Thanks Carl for your information,
Thu Le Anh
On Friday, September 26, 2014 1:32:41 AM UTC+7, chartung wrote:
> Hi Thu Le Anh,
> -Carl
> On Wed, Sep 24, 2014 at 3:00 AM, Thu Le Anh <mr.le...@gmail.com > wrote:
>> Dear all,
>> 1. I can't do the cascading with the external itemset (the form as the
>> attached)
>> 2. After deleting the form with external itemset, I get new form with
>> that form again. Collect can't read the form & crash after then. I think
>> the issue could be itemset db since metadata is not deleted after deleting
>> the form.
>> Thu Le Anh
>> "ODK Community" group.
