in certain select multiple or select one questions within a looped
group, the selected options change when enumerator swipes back to the
page (from within the looped group, to check a past selection for
example). For example, if on the first go, options 1 and 5 were
selected, and the enumerator later swipes back to that page options 5
and 6 show as selected.
anyone else experiencing this?
Can you file an issue and attach a sample form? Make sure to include
the device you are using, the version of Android and Collect you are
using.
