Issues installing ODK aggregate
Hello,
I receive the error message below when trying to install ODK aggregate.
Please advise?
Many thanks!
Beginning interaction for module default...
Warning: This application uses Backends, a deprecated feature that has been
replaced by Modules, which offers additional functionality. Please convert
your backends to modules as described at:
https://developers.google.com/appengine/docs/java/modules/converting.
0% Rolling back the update on backend background.
Dec 02, 2014 6:37:48 PM
com.google.appengine.tools.admin.AbstractServerConnection send1
WARNING: Error posting to URL:
https://appengine.google.com/api/appversion/rollback?backend=background&app_id=psi-liberia-research&
401 Unauthorized
Must authenticate first.
This is try #0
Please see the logs
[C:\Users\psiuser\AppData\Local\Temp\appcfg7893268278543808568.log] for
further information.
*---END-SCRIPT-SUCCESS--- *
401 UnauthorizedMust authenticate first.
The gmail account and password you supplied were not correct. This commonly
occurs if you are using two-factor authentication on the gmail account you
entered into the upload script; you need to get an application-specific
password and use that during the upload process. Google for "Google
application-specific password" and follow the instructions.
··· On Tue, Dec 2, 2014 at 10:50 AM, Danielle Lloyd wrote:
Hello,
Please advise?
Many thanks!
been replaced by Modules, which offers additional functionality. Please
convert your backends to modules as described at:
401 Unauthorized
This is try #0
Please see the logs
