Hello,
i want my input field to only accept 5 digits and the code is
However, its working but ungortunately it is not recognizing leading zeros
as digits
i.e 00001 is not valid but yet contains 5 digits
how can make leading zeros be recognized.
haven't tested this, but try 'regex(,[0-9]{5})'
On Mon, Aug 1, 2011 at 06:34, Gichure wrote: > Hello, > i want my input field to only accept 5 digits and the code is > relevant="(/data/similar=0)" constraint="regex(., '^\d\d\d\d\d$')" > jr:constraintMsg="This isn't a valid EA code.Enter 5 digits only"/> > However, its working but ungortunately it is not recognizing leading zeros > as digits > i.e 00001 is not valid but yet contains 5 digits > how can make leading zeros be recognized. > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >good catch, andrew.
if you are using collect 1.1.7, you can set the type to string and add
an appearance tag like so . that will bring up the number keyboard.
yaw
On Mon, Aug 1, 2011 at 06:43, Andrew Marder wrote: > Hi Gichure, > > I believe changing the type from "int" to "string" will allow for > leading zeros. The downside to this approach is that the on screen > keyboard will show letters rather than numbers. I recall some mentions > on this list about specifying which keyboard to use, but I don't > remember the syntax. > > Andrew > > On Mon, Aug 1, 2011 at 9:34 AM, Gichure wrote: >> Hello, >> i want my input field to only accept 5 digits and the code is >> > relevant="(/data/similar=0)" constraint="regex(., '^\d\d\d\d\d$')" >> jr:constraintMsg="This isn't a valid EA code.Enter 5 digits only"/> >> However, its working but ungortunately it is not recognizing leading zeros >> as digits >> i.e 00001 is not valid but yet contains 5 digits >> how can make leading zeros be recognized. >> >> -- >> Gichure Paul >> Regards. >> >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >Hi Gichure,
Andrew
On Mon, Aug 1, 2011 at 9:34 AM, Gichure wrote: > Hello, > i want my input field to only accept 5 digits and the code is > relevant="(/data/similar=0)" constraint="regex(., '^\d\d\d\d\d$')" > jr:constraintMsg="This isn't a valid EA code.Enter 5 digits only"/> > However, its working but ungortunately it is not recognizing leading zeros > as digits > i.e 00001 is not valid but yet contains 5 digits > how can make leading zeros be recognized. > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >have done it before and had issues with making it exact 5 digits. i could
only manage to make it read 5 or more digits. help on how to get strictly 5
digits only
On Mon, Aug 1, 2011 at 4:43 PM, Andrew Marder wrote:Hi Gichure,
remember the syntax.Andrew
On Mon, Aug 1, 2011 at 9:34 AM, Gichure gichurepaul@gmail.com wrote:
Hello,
zeros
as digits
how can make leading zeros be recognized.--
Gichure Paul
Regards.--
Gichure Paul
Regards.
will match exactly five digits.
On Mon, Aug 1, 2011 at 06:52, Gichure wrote: > have done it before and had issues with making it exact 5 digits. i could > only manage to make it read 5 or more digits. help on how to get strictly 5 > digits only > > On Mon, Aug 1, 2011 at 4:43 PM, Andrew Marder wrote: >> >> Hi Gichure, >> >> I believe changing the type from "int" to "string" will allow for >> leading zeros. The downside to this approach is that the on screen >> keyboard will show letters rather than numbers. I recall some mentions >> on this list about specifying which keyboard to use, but I don't >> remember the syntax. >> >> Andrew >> >> On Mon, Aug 1, 2011 at 9:34 AM, Gichure wrote: >> > Hello, >> > i want my input field to only accept 5 digits and the code is >> > > > relevant="(/data/similar=0)" constraint="regex(., '^\d\d\d\d\d$')" >> > jr:constraintMsg="This isn't a valid EA code.Enter 5 digits only"/> >> > However, its working but ungortunately it is not recognizing leading >> > zeros >> > as digits >> > i.e 00001 is not valid but yet contains 5 digits >> > how can make leading zeros be recognized. >> > >> > -- >> > Gichure Paul >> > Regards. >> > >> > >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >Sir,
What if i want digit length like between 2 to 5... in your expression
regex(., '^[0-9]{5}$')
I have tried this - regex(., '^[0-9]{2-5}$') but ODK collect crashed every time..
My Requirement is to allow only alphabets A-Z a-z and total digit must be between 2 to 5... as i m gonna use this query for NAME field...
help me plz to solve it out.
On Tuesday, August 2, 2011 8:54:47 AM UTC+5:30, Yaw Anokwa wrote: > constraint="regex(., '^[0-9]{5}$')" jr:constraintMsg="five digits > only"/> > > will match exactly five digits. > > > On Mon, Aug 1, 2011 at 06:52, Gichure wrote: > > have done it before and had issues with making it exact 5 digits. i could > > only manage to make it read 5 or more digits. help on how to get strictly 5 > > digits only > > > > On Mon, Aug 1, 2011 at 4:43 PM, Andrew Marder wrote: > >> > >> Hi Gichure, > >> > >> I believe changing the type from "int" to "string" will allow for > >> leading zeros. The downside to this approach is that the on screen > >> keyboard will show letters rather than numbers. I recall some mentions > >> on this list about specifying which keyboard to use, but I don't > >> remember the syntax. > >> > >> Andrew > >> > >> On Mon, Aug 1, 2011 at 9:34 AM, Gichure wrote: > >> > Hello, > >> > i want my input field to only accept 5 digits and the code is > >> > >> > relevant="(/data/similar=0)" constraint="regex(., '^\d\d\d\d\d$')" > >> > jr:constraintMsg="This isn't a valid EA code.Enter 5 digits only"/> > >> > However, its working but ungortunately it is not recognizing leading > >> > zeros > >> > as digits > >> > i.e 00001 is not valid but yet contains 5 digits > >> > how can make leading zeros be recognized. > >> > > >> > -- > >> > Gichure Paul > >> > Regards. > >> > > >> > > >> > -- > >> > Post: opendatakit@googlegroups.com > >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > >> > Options: http://groups.google.com/group/opendatakit?hl=en > >> > > >> > >> -- > >> Post: opendatakit@googlegroups.com > >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com > >> Options: http://groups.google.com/group/opendatakit?hl=en > > > > > > > > -- > > Gichure Paul > > Regards. > > > > > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > >That regex looks fine to me, so something else might be going on. File
a bug report at https://code.google.com/p/opendatakit/issues with the
make/model of the device you are using and version of Collect you have
installed.
Attach a one or two question form that shows this problem and attach a
stack trace (see
https://code.google.com/p/opendatakit/wiki/CollectTroubleshooting) so
the core team knows exactly what the error is.
-- Need ODK services? Go to http://nafundi.com for form design, data cleaning, custom reporting, and software development for ODK.On Fri, Jul 19, 2013 at 5:54 AM, palaksdarji@gmail.com wrote:
Sir,
regex(., '[1]{5}$')I have tried this - regex(., '[2]{2-5}$') but ODK collect crashed every time..
digits onlyOn Mon, Aug 1, 2011 at 4:43 PM, Andrew Marder andrew.ei.marder@gmail.com wrote:
Hi Gichure,
Hello,
zeros
as digits
Gichure Paul
Regards.--
Gichure Paul
Regards.--
