Jr:choice-name() not working for a select_one question within repeat group
I'm trying to calculate the label of selection from a select_one within a repeat group for using it in next question labels. But, it's not working.
Hi @Likhon
it's difficult to tell what's wrong with your form because you didn't attach it but here is a sample form I prepared some time ago which shows exactly what you need: choice_name_and_indexed-repeat.xls (7.5 KB)
Hi Grzesiek!
Thank you for your reply. I want the bame within same repeat group. Usually we use jr:choice-name(${ver}, '${ver}) for calculate the label. But, this syntax is not working in a repeat group.
Could you attach your form it would be easier? It might be the same problem Jr:choice-name doesn't give a value when called from inside a repeat group
I think so. Is there any solution? Here is the attachment
test.xlsx (12.6 KB)
Hi @Likhon
I checked the example you posted and I think some fields are mixed up.
I've made some corrections to it (see attached test_.xlsx (10.5 KB) ), in case other people can assist:
  • repeat_count (cell G4, referencing the number of hh members)
  • calculate (cell F6, referencing var q2)
FYI, it looks like this bug was fixed in the new release (ODK Collect v1.24 Beta). I haven't personally tested it yet, but you might want to give it a try.
I hope this helps!
Andrea
Hi andrea!
Sorry for my mistake. But, actually I tried as your correction. Maybe, this is for the bug. Thanks for the recommendation. Now, I will try it.
