I am running aggregate version 1.4.4 on GAE. I am trying to stream data for a form from Aggregate to a webserver but I am getting an empty post - array(0). I have tried everything, but post is always empty for some strange reason.
On the same web server, I am fetching JSON data successfully for 20 other forms from Aggreagte, the only difference is that the Aggregate version in 1.3.3. I did check the release notes and realized the that publisher changes between the two version, however, the JSON data is still being sent as POST.
PS: I tried the form on version 1.4.4 with Aggergate version 1.3.3 and the JSON export now works! However, I can't downgrade to Aggreagte 1.3.3 as changing the GAE application ID is out of question.
Any help fixing the JSON publishing on v1.4.4? Thanks.
Are there any errors reported in your 1.4.4 server's error logs?
Note that the Simple JSON publisher was changed between 1.3.4 and 1.4.1
If your server is handling submissions from 1.3.4 but not from 1.4.4, then
you probably need to update how your server is parsing the entity body that
ODK Aggregate is sending, as it did change between those two releases.
You also may need to choose to upload existing data and stream new data
when setting up your publisher -- otherwise a streaming-only publisher
would emit a single empty publishing request then sit idle waiting for a
new submission to arrive (and then a few seconds after it arrives, it would
attempt to publish that one submission to the JSON server). This might
explain the behavior you are seeing.
strange reason.
as POST.
"ODK Developers" group.
Thanks, Mitch, for your response. I checked for server's error log and there was nothing to indicate a problem. In fact, I can verify from my server that I am receiving the post from aggregate server but it is empty. I also checked for app-engine app logs and found nothing. I, in fact, checked the same on three different web servers - one shared, one VPS and one dedicated, but with the same results. On all three servers, I could receive post from Aggregate 1.3.2 but an empty post from 1.4.4.
I also checked the ODK Post Receiver, and while it receives the post from GAE installed version, it gets the same empty post when hosted on external web servers. Is there a possibility that GAE is somehow not posting anything to an external IP? But then, since it does on 1.3.4, it makes me think otherwise.
I know things have changed between 1.3.4 and 1.4.1 with regards to JSON publishing, but since the data is still being sent as POST, I assume I should at least receive it as an array on my server in whatever format it now comes in.
Yes, I always publish existing records+stream. I get an empty array for each existing record, so if I have 10 records for a form, I see 10 array(0) in the POST that I receive.
Thanks.
> If your server is handling submissions from 1.3.4 but not from 1.4.4, then you probably need to update how your server is parsing the entity body that ODK Aggregate is sending, as it did change between those two releases.
> You also may need to choose to upload existing data and stream new data when setting up your publisher -- otherwise a streaming-only publisher would emit a single empty publishing request then sit idle waiting for a new submission to arrive (and then a few seconds after it arrives, it would attempt to publish that one submission to the JSON server). This might explain the behavior you are seeing.
> Mitch
> You received this message because you are subscribed to the Google Groups "ODK Developers" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
I was able to finally fix this. I have been using PHP var_dump function to get the contents of post earlier, but I had to instead use the file_get_contents('php://input') function. It di pose another set of problems as this particular function returns the post data as string. I had to change my code significantly to make it work fully, but it did work, finally.
> Thanks.
> > Mitch
> > Mitch Sundt
> > Software Engineer
> > mitche...@gmail.com
Good. Glad to hear it. Testing using requestbin.in shows that everything is
working fine with this functionality, at least w.r.t. the server.
finally.
now comes in.
Thanks.
strange reason.
being sent as POST.
mitche...@gmail.com
