somebody help
My Aggreagte apllication is not exporting .kml files but works fine when i
export .csv What could be the problem?
what version are you using? does it give you any errors? what are the
exact steps you go thru and where does the problem occur?
On Mon, Aug 8, 2011 at 07:02, Gichure wrote: > somebody help > My Aggreagte apllication is not exporting .kml files but works fine when i > export .csv What could be the problem? > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >I am using ODK Aggreagte V1.0 beta.
While I am under forms list, I click on EXPORT button associated with my
form/data. A popup windo pops and with form id. When i select CSV file, it
works fine but when i select nothing happens. No error, no message, no
action.
On Mon, Aug 8, 2011 at 5:16 PM, Yaw Anokwa wrote:what version are you using? does it give you any errors? what are the
exact steps you go thru and where does the problem occur?On Mon, Aug 8, 2011 at 07:02, Gichure gichurepaul@gmail.com wrote:
somebody help
i
export .csv What could be the problem?--
Gichure Paul
Regards.--
Gichure Paul
Regards.
The file should be available under the exported files tab.
We are working on making the UI easier right now. Apologies for the
confusion and thanks for testing Aggregate while we put on the
finishing touches!
Waylon
On Tue, Aug 9, 2011 at 12:29 AM, Gichure wrote: > I am using ODK Aggreagte V1.0 beta. > While I am under forms list, I click on EXPORT button associated with my > form/data. A popup windo pops and with form id. When i select CSV file, it > works fine but when i select nothing happens. No error, no message, no > action. > > On Mon, Aug 8, 2011 at 5:16 PM, Yaw Anokwa wrote: >> >> what version are you using? does it give you any errors? what are the >> exact steps you go thru and where does the problem occur? >> >> On Mon, Aug 8, 2011 at 07:02, Gichure wrote: >> > somebody help >> > My Aggreagte apllication is not exporting .kml files but works fine when >> > i >> > export .csv What could be the problem? >> > >> > -- >> > Gichure Paul >> > Regards. >> > >> > >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >On the mentioned tab i only locate .csv files only and none of type .kml.
thats why i cann't figure out the problem. Everything seems to work well on
previous versions of Aggregate
On Tue, Aug 9, 2011 at 10:37 AM, W. Brunette wrote:The file should be available under the exported files tab.
finishing touches!Waylon
it
somebody help
wheni
Gichure Paul
Regards.--
Gichure Paul
Regards.--
Gichure Paul
Regards.
Can you file an issue on the Open Data Kit code site with the form
that is not creating an kml and (if possible) a link to your aggregate
instance.
Waylon
On Tue, Aug 9, 2011 at 12:50 AM, Gichure wrote: > On the mentioned tab i only locate .csv files only and none of type .kml. > thats why i cann't figure out the problem. Everything seems to work well on > previous versions of Aggregate > > On Tue, Aug 9, 2011 at 10:37 AM, W. Brunette wrote: >> >> The file should be available under the exported files tab. >> >> We are working on making the UI easier right now. Apologies for the >> confusion and thanks for testing Aggregate while we put on the >> finishing touches! >> >> Waylon >> >> On Tue, Aug 9, 2011 at 12:29 AM, Gichure wrote: >> > I am using ODK Aggreagte V1.0 beta. >> > While I am under forms list, I click on EXPORT button associated with my >> > form/data. A popup windo pops and with form id. When i select CSV file, >> > it >> > works fine but when i select nothing happens. No error, no message, no >> > action. >> > >> > On Mon, Aug 8, 2011 at 5:16 PM, Yaw Anokwa wrote: >> >> >> >> what version are you using? does it give you any errors? what are the >> >> exact steps you go thru and where does the problem occur? >> >> >> >> On Mon, Aug 8, 2011 at 07:02, Gichure wrote: >> >> > somebody help >> >> > My Aggreagte apllication is not exporting .kml files but works fine >> >> > when >> >> > i >> >> > export .csv What could be the problem? >> >> > >> >> > -- >> >> > Gichure Paul >> >> > Regards. >> >> > >> >> > >> >> > -- >> >> > Post: opendatakit@googlegroups.com >> >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> > Options: http://groups.google.com/group/opendatakit?hl=en >> >> > >> >> >> >> -- >> >> Post: opendatakit@googlegroups.com >> >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > >> > >> > -- >> > Gichure Paul >> > Regards. >> > >> > >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >url is population-council.appspot.com. it has has that onyl that form
On Tue, Aug 9, 2011 at 8:00 PM, W. Brunette wrote:Can you file an issue on the Open Data Kit code site with the form
instance.Thanks,
on
previous versions of AggregateOn Tue, Aug 9, 2011 at 10:37 AM, W. Brunette wbrunette@gmail.com wrote:
myform/data. A popup windo pops and with form id. When i select CSV
file,it
somebody help
when
i
Gichure Paul
Regards.--
Gichure Paul
Regards.--
Gichure Paul
Regards.--
Gichure Paul
Regards.
please add wbrunette@gmail.com and yanokwa@gmail.com as administrators
on that instance so we can take a look. as it stands, we can't login
On Wed, Aug 10, 2011 at 02:26, Gichure wrote: > url is population-council.appspot.com. it has has that onyl that form > > On Tue, Aug 9, 2011 at 8:00 PM, W. Brunette wrote: >> >> Can you file an issue on the Open Data Kit code site with the form >> that is not creating an kml and (if possible) a link to your aggregate >> instance. >> >> Thanks, >> Waylon >> >> On Tue, Aug 9, 2011 at 12:50 AM, Gichure wrote: >> > On the mentioned tab i only locate .csv files only and none of type >> > .kml. >> > thats why i cann't figure out the problem. Everything seems to work well >> > on >> > previous versions of Aggregate >> > >> > On Tue, Aug 9, 2011 at 10:37 AM, W. Brunette wrote: >> >> >> >> The file should be available under the exported files tab. >> >> >> >> We are working on making the UI easier right now. Apologies for the >> >> confusion and thanks for testing Aggregate while we put on the >> >> finishing touches! >> >> >> >> Waylon >> >> >> >> On Tue, Aug 9, 2011 at 12:29 AM, Gichure wrote: >> >> > I am using ODK Aggreagte V1.0 beta. >> >> > While I am under forms list, I click on EXPORT button associated with >> >> > my >> >> > form/data. A popup windo pops and with form id. When i select CSV >> >> > file, >> >> > it >> >> > works fine but when i select nothing happens. No error, no message, >> >> > no >> >> > action. >> >> > >> >> > On Mon, Aug 8, 2011 at 5:16 PM, Yaw Anokwa wrote: >> >> >> >> >> >> what version are you using? does it give you any errors? what are >> >> >> the >> >> >> exact steps you go thru and where does the problem occur? >> >> >> >> >> >> On Mon, Aug 8, 2011 at 07:02, Gichure wrote: >> >> >> > somebody help >> >> >> > My Aggreagte apllication is not exporting .kml files but works >> >> >> > fine >> >> >> > when >> >> >> > i >> >> >> > export .csv What could be the problem? >> >> >> > >> >> >> > -- >> >> >> > Gichure Paul >> >> >> > Regards. >> >> >> > >> >> >> > >> >> >> > -- >> >> >> > Post: opendatakit@googlegroups.com >> >> >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> >> > Options: http://groups.google.com/group/opendatakit?hl=en >> >> >> > >> >> >> >> >> >> -- >> >> >> Post: opendatakit@googlegroups.com >> >> >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> > >> >> > >> >> > >> >> > -- >> >> > Gichure Paul >> >> > Regards. >> >> > >> >> > >> >> > -- >> >> > Post: opendatakit@googlegroups.com >> >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> > Options: http://groups.google.com/group/opendatakit?hl=en >> >> > >> >> >> >> -- >> >> Post: opendatakit@googlegroups.com >> >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > >> > >> > -- >> > Gichure Paul >> > Regards. >> > >> > >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > > > -- > Gichure Paul > Regards. > > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >Ok, already done it.
On Wed, Aug 10, 2011 at 6:10 PM, Yaw Anokwa wrote:please add wbrunette@gmail.com and yanokwa@gmail.com as administrators
instance.Thanks,
.kml.
wellon
withmy
file,
it
no
the
somebody help
fine
when
i
Gichure Paul
Regards.--
Gichure Paul
Regards.--
Gichure Paul
Regards.--
Gichure Paul
Regards.--
Gichure Paul
Regards.
just following up so everyone knows...
there was indeed a bug in aggregate and it's been fixed at
http://code.google.com/p/opendatakit/source/detail?r=b260710c6d&repo=aggregate.
the change will be pushed out to everyone in a few weeks.
