When I export my XLSForm to XML to upload to my Google drive, I get an error about languages: "The following language declarations do not contain valid machine-readable codes". I am using 4 languages, two of which are not on the list that provides the two-letter language code. These two are Acholi and Lusoga, dialiects in Uganda. I had no problem with these when using Kobotoolbox with the XLSForm, but now, the answer choices are not being recognized. Can we create new two-letter language codes?
Hi, thanks so much for this response. Originally it was just showing dashes for all answer choices in Lusoga and Acholi. Oddly enough, the questions were working though. I just removed the code I had made up on both the survey and choices sheets, and like you said, it now works. I will try those suggested codes again and see if this holds.
