I have a select one question with multiple languages and audio for the responses, but the audio doesn't show up when likert is in the appearance column.
Make a select one question with choices that have audio. Verify the audio shows up when appearance column is blank. Then add likert to appearance column and you'll see in Collect that the audio buttons have disappeared and the audio doesn't play when an answer is selected.
Toggled on and off likert in the appearance column.
