hey, i installed the newest java update and odk aggregate to my
computer, i unzipped it and created the script. odk collect is already
on my android phone. i also have an authorized app engine account.
following problem: once i go to my id: internewsrwanda.appspot.com and
try to log on to the server it doesnt work. if i try to log onto it
via aggregate password, i dont have any idea where i should have
gotten this password from or should get it from now. and if i try to
connect using my google account it also doesnt work. i only get the
following
The first time you log onto your server, you should Sign in with Google
and specify the super-user eMail you specified in the installer during the
configuration process (before the upload to AppEngine). You may have
mistyped that name or not used "john.m.preuss@googlemail.com".
To see what e-mail you specified, you can go to https://appengine.google.com,
click on your application, then, on the Dashboard page, choose Logs on the
left sidebar. From there, choose to show all logs, open the 'Options'
fold-up, and enter superUserEmail into the Filter textbox and click Search.
You can then search down the page of returned log entries, and you'll find
an entry like this:
2011-12-14 18:09:56.320 org.opendatakit.common.security.spring.UserServiceImpl
afterPropertiesSet: superUserEmail: mailto:mitchellsundt@gmail.comWhich
shows that the server was configured with "mitchellsundt@gmail.com" during
the installation process.
Aggregate usernames and passwords are configured on the Site Admin tab,
under the Permissions sub-tab.
following
Okay, I tried this. Problem! I think, yesterday I actually signed my
googlename and password and everything in. Then I was asked if I gave
them authorization for my email and stuff and I confirmed. The only
problem, I never got directed to the site. And when I click on sign in
with google they never actually let me sign in. they directly tell me
this: Error: Authentication Failed: account not recognized.
i checked the logs and everything. anyhow, it doesnt work. could there
be a certificate missing or anything?
hope for a soon reply
thanks
Note that the super-user eMail must match exactly -- since Google reports " john.m.preuss@googlemail.com", you MUST use that all-lower-case string.
I.e., specifying "John.M.Preuss@googlemail.com" during the ODK Aggregate
configuration process will cause your login to fail.
If that isn't an issue, if you get the Authentication Failed during the
Google sign-in, then it is typically a problem with your e-mail address or
password not being recognized by Google.
Try this:
Open your browser, log out of any Google account you're using.
Close all your browser windows.
Open your browser, and log into this account (john.m.preuss@googlemail.com),
then, open a URL to your aggregate instance.
Does that change anything?
I have not experimented with Google Accounts Multiple Sign-In. Are you
using that? (i.e., do you have multiple user accounts on Google and have
them tied together so you can share a common login process?). This might
also be tripping up the logic on the ODK Aggregate side.
Otherwise, you can invite me to be a Developer on your appEngine instance
and I'll see if I can see anything wrong in the logs. See:
http://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
thanks
Also, I just noticed that the upload script can report SUCCESS when it
fails due to a bad username/password combination. Be sure the script
reports completion %'s and numbers of files uploaded.
Try this:
thanks
> Mitch
> > Try this:
> > Mitch
> > On Thu, Dec 15, 2011 at 11:10 PM, John-Martin Preuss < john.m.preuss@googlemail.com> wrote:
> >> thanks
> >> Post: opendatakit@googlegroups.com
> >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
> >> Options:http://groups.google.com/group/opendatakit?hl=en
> > Mitch Sundt
> > Software Engineer
> > University of Washington
> Mitch Sundt
> Software Engineer
You specified john.m.preuss@gmail.com instead of john.m.preuss@ googlemail.com during your install process. You will need to re-run the
installer and specify the correct e-mail address.
FYI, the logs are available from the dashboard via
Click on the "Logs" heading on the left sidebar.
On the logs page, choose to view all requests.
You can then search for 'afterPropertiesSet' to see what configuration
values you specified during the installation( the Realm string is the 'ODK
Aggregate Instance Name' supplied to the installer, with " ODK Aggregate"
appended to it).
On Sun, Dec 18, 2011 at 11:29 PM, John-Martin Preuss < john.m.preuss@googlemail.com> wrote:
string.
Aggregate
address or
Try this:
Open your browser, and log into this account ( john.m.preuss@googlemail.com),
have
might
thanks
I hope it's ok to use this thread and add our "log in issues".
We set up a clean installation of ODK Aggregate (1.0.3) on our
production server (Ubuntu 10.04 Server).
The installation of Tomcat, PostgreSQL and ODK Aggregate worked
without problems. But now we cannot log in to ODK Aggregate.
All we get is:
"HTTP Status 401 - Authentication Failed: Unable to process claimed
identity 'https://www.google.com/accounts/o8/id'"
This error page is shown directly without any loading time. And it
doesn't matter if we are already logged in to Gmail etc...
I checked the logs to make sure that we specified the correct
"superUserEmail". And it is the right one. (...@googlemail.com)
Are there any differences between an ODK Aggregate on Windows and
Linux? Because our test system is running fine on Windows 7. So I knew
how to set up an Aggregate server and wasn't expecting any problems...
Regards!
On Dec 19, 6:43 pm, Mitch S wrote:
> Hi John,
> You specified john.m.pre...@gmail.com instead of john.m.preuss@
> From the Logs:
> org.opendatakit.common.security.spring.UserServiceImpl afterPropertiesSet:
> superUserEmail: mailto:john.m.pre...@gmail.com
> FYI, the logs are available from the dashboard viahttps://appengine.google.com
> appended to it).
> Mitch
> On Sun, Dec 18, 2011 at 11:29 PM, John-Martin Preuss < john.m.pre...@googlemail.com> wrote:
> > Problem not solved,
> > just invited you,
> > thanks
> > > Mitch
> > reports "
> > > > john.m.pre...@googlemail.com", you MUST use that all-lower-case
> > string.
> > > > I.e., specifying "John.M.Pre...@googlemail.com" during the ODK
> > Aggregate
> > address or
> > > > Try this:
> > john.m.pre...@googlemail.com),
> > have
> > might
> > instance
> > > > Mitch
> > > > On Thu, Dec 15, 2011 at 11:10 PM, John-Martin Preuss < john.m.pre...@googlemail.com> wrote:
> > > >> thanks
> > > > Mitch Sundt
> > > > Software Engineer
> > > > mitchellsu...@gmail.com
> > > Mitch Sundt
> > > Software Engineer
> Mitch Sundt
> Software Engineer
But then I deployed an old ODK Aggregate Server (v.1.0 Prod) and the
log in worked fine (in my case with a "...@gmail.com" superUserEmail).
After that I could update ODK Aggregate to v1.0.3 and the log in still
works fine.
Hope that helps.
On Dec 21, 10:24 am, LETSGO CeLeKT wrote:
> Hi,
> All we get is:
> "superUserEmail". And it is the right one. (....@googlemail.com)
> Regards!
> > Hi John,
> > From the Logs:
> > appended to it).
> > Mitch
> > > Problem not solved,
> > > just invited you,
> > > thanks
> > > > Mitch
> > > reports "
> > > string.
> > > Aggregate
> > > address or
> > > > > Try this:
> > > have
> > > might
> > > instance
> > > > > Mitch
> > > > >> thanks
> > > > > Mitch Sundt
> > > > > Software Engineer
> > > > Mitch Sundt
> > > > Software Engineer
> > Mitch Sundt
> > Software Engineer
