I think the easiest way to solve the age problem is to start with an
age entry mode that asks if age is being entered by date or age in
years. On that screen, you can also add 'Don't Know'. Then your next
prompt will ask the appropriate question.
On Thu, Jan 26, 2012 at 07:37, Evelyn Castle wrote:
> Hi All,
> I am working on a pretty long and complex form and was hoping to get
> some help with one of my questions.
> We have many questions where the participant can either answer the
> question or choose "Don't Know" as an option. For example:
> 1. How many years old are you? ________
> Don't know
> I have put these into a group so that they show up on the same screen
> together.
> Now, I need to add logic to make it so the surveyor has to choose one
> or the other, but not both, before they can move onto the next
> question.
> Any ideas?
> Thanks
> Evelyn
Evelyn is building the form for a project I am running. Your suggestion
doesn't really help us because we are not allowing the enumerator to choose
how to enter the age. She must enter it in completed years. We have the
same problem with dates, for example:
What is your date of birth:
day: |||
month: |||
year: |||
don't know
Here they have to enter at least the year of birth or "don't know".
One alternative is to train enumerators to enter -99 if not even the year
is known, but we were looking for a neater solution where we could still
keep the "don't know" option, but make it possible for them to choose one
one or the other without skipping the question.
Laura
On Thu, Jan 26, 2012 at 4:42 PM, Yaw Anokwa wrote:
Hi Evelyn,
To clarify a bit on what Laura was saying, I would like to be able to have
logic that says:
at least 1 question in a group must be answered
only 1 question in a group can be answered
Is that logic possible?
Sorry, the birth date question was probably not the best example.
Evelyn
On Fri, Jan 27, 2012 at 4:29 PM, Laura Costica wrote:
Hi Yaw,
day: |||
month: |||
year: |||
don't know
Laura
On Thu, Jan 26, 2012 at 4:42 PM, Yaw Anokwa yanokwa@gmail.com wrote:
Hi Evelyn,
I think the best you can do is to ask what they know or don't know in
a first prompt, then have the next set of prompts ask for the known
data. There is no way that I know of to apply logic on an entire group
and there is also no way to have prompts in a group dynamically change
while that group is being displayed. Maybe Drew or Clayton know a
clever way around this, but I can't think of one...
On Fri, Jan 27, 2012 at 07:43, Evelyn Castle wrote:
> Hi Yaw,
> logic that says:
> - at least 1 question in a group must be answered
> - only 1 question in a group can be answered
> Thanks
> Evelyn
>> Hi Yaw,
>> how to enter the age. She must enter it in completed years. We have the same
>> day: |__|__|
>> month: |__|__|
>> year: |__|__|
>> don't know
>> Thanks,
>> Laura
>>> Hi Evelyn,
>>> See the sample form at http://pastie.org/3257103.
>>> Yaw
>>> > Hi All,
>>> > Don't know
>>> > together.
>>> > question.
>>> > Any ideas?
>>> > Thanks
>>> > Evelyn
> Evelyn Castle
> Director, eHealth Nigeria
> www.eHealthNigeria.org
> 25 Race Course Road, Kano, Ng
> mobile: (NG) 0809-515-0585
> (NG) 0813-883-2395
> (US) 714-721-3157
I think one of the two things you're looking for is possible.
at least 1 question in a group must be answered--
If all of your questions are on the same screen, you can just make the
"required=" logic for the last question to say if all of the other
questions are blank, then this question is required. That will prevent the
user from going forward until at least one question is answered.
only 1 question in a group can be answered--
In theory, you should be able to do put a constraint on the current
question based on a previous answer. Something like:
(constraint for q4
is that the answer to q3 is greater than 5)
but it appears javarosa doesn't support this. it only supports the "."
operator, so constraints can only relate to the current node.
So I don't think this is currently possible.
Hope that helps.
-Carl
On Sun, Jan 29, 2012 at 2:17 PM, Yaw Anokwa wrote:
Evelyn,
choose
same
day: |||
month: |||
year: |||
don't know
year
one
Laura
Hi Evelyn,
On Mon, Jan 30, 2012 at 5:21 AM, Carl Hartung wrote:
Hi Evelyn,
(constraint for
q4 is that the answer to q3 is greater than 5)
Hope that helps.
-Carl
On Sun, Jan 29, 2012 at 2:17 PM, Yaw Anokwa yanokwa@gmail.com wrote:
Evelyn,
choose
the same
day: |||
month: |||
year: |||
don't know
year
still
one
Laura
Hi Evelyn,
(constraint for
Hope that helps.
-Carl
Evelyn,
suggestion
choose
the same
day: |||
month: |||
year: |||
don't know
year
still
one
Laura
Hi Evelyn,
(constraint for
Hope that helps.
-Carl
Evelyn,
suggestion
choose
the same
day: |||
month: |||
year: |||
don't know
year
still
choose one
Laura
Hi Evelyn,
