Login to ODK Central using appuser token
  • appuser tokens give access to specific forms.
  • Currently login to Central is via username and password for site-wide auth.
  • It would be great if an alternative login flow was possible: login using an appuser token, where the user has restricted access / goes directly to the project detail page, with access only to the forms that the appuser has permissions to see.
Possible useful scenarios:
  • Open up flows for external apps to easily open up pages directly in ODK Central, such as the submission details page, or form editing page.
  • Some users manage multiple forms within the same project, where each manager should only access a subset of the forms (discussed at ODK Summit). This would enable access to the form on the Central UI, without needing to make multiple site-wide roles on the instance.
  • We could also use the built in appuser permission levels, as an alternative to creating lots of new site-wide role types for specific requirements (e.g. a user than can only edit a specific form).
  • Currently the API supports auth via appuser token.
  • I imagine it wouldn't be a huge lift to enable login to the UI using appuser tokens too?
This sounds interesting.
Sorry to hijack, but maybe would also solve / move forward an earlier idea:
Specifically you mention...
Does that also (potentially) mean that if access to Central via an appuser token were implemented, we could access the submissions from the relevant form(s) for that appuser (and accessible Entities) from the API instead of needing a webuser? That could be a really useful tool for QuODK to manage access more effectively / with some granularity (assuming the right strategy for app users!)...
Thanks for linking the other thread! That was exactly the idea I had in mind :smiley:
Yes, I think having the option for adding user credentials OR appuser token in QuODK could solve your problem!
The docs reference here says 'App Users are only allowed to list and download forms, and upload new submissions to those forms.', so I think appuser tokens can possibly only be used for a subset of the API.
Viewing submission isn't included in the actions there though, so it would need a bit of testing to confirm if viewing / downloading submissions is possible via appuser token :+1:
I agree that it's not currently possible to download submissions - I had been looking closely at the docs in the early stages of development... In my naivety I'm hopeful that because there is essentially two-way traffic (i.e. download form, upload submission) with the appuser token, it might 'just' require building out using existing procedures rather than a whole new process... However, I wonder if it would cause security issues with Android devices potentially able to download submissions? Which might be why this hasn't been implemented?
But the idea seems simple, so obviously I like it :slight_smile:
Looking into the code, there is a very clear separation between UI users and appusers.
I think it would be quite a challenge to allow app users login access in a clean way, and perhaps not desirable.
An alternative could be a new UI user type such as ‘Submission Reviewer', which has access to only specific forms, with submission viewing and editing capabilities.
This would need much fewer changes to the code :smiley:
