Longitudinal Workflow with Entities
The longitudinal data collection feature in the form of entities was an exciting feature that opened new possibilities in data collection with ODK.
I was able to design a workflow using entities and maintain a data collection spanning a few months across multiple LGAs in rural, sub-rural and urban areas. Here is the workflow in parts:
Thanks to a fellow ODK Insider and colleague @Certified_Bashir for the help in implementing and maintaining the workflow.
Part 1: The ''Registration'' Form
This is the first contact form with the entity to be collected; it is the form that adds an entity to the entities table, and it uses some values from the submission to create the initial table.
The entities table saves some data points that uniquely identify the entity, e.g., lga, ward, and GPS (which is subsequently used for geofencing), along with variables that could potentially change.
Part 2: The ''Follow-Up Survey'' Form
The forms used subsequently in the study are used to collect similar data over time, which is where ODK entities shine for longitudinal studies and where the workflow begins to take shape. The forms are administered periodically.
  • Entity Selection
An entity is selected using its label, which is set using the baseline form; other details are used to verify the entity by pulling some attributes and displaying them to the enumerator. They have to acknowledge to move forward,
  • GPS Validation
The next level of validation is a location check. The enumerator has to capture their GPS location. Then, using the location captured on baseline from the entities, the points are compared using the distance function; every follow-up form uses this validation check before being administered. This ensures that the enumerator will have access to the form only when in the designed structure.
  • Comparison of variables
Thanks to the forms having access to the entities, another important aspect of the workflow is the ability to display previous values to the enumerator, which allows them to provide context if/when there are changes, using the lookup function. A section is dedicated to pulling these data elements and then referencing them on the label of similar data points.
  • Entity Update
After submission, each form creates or updates an entity variable. Most of the variables that were compared are then updated, an example of such variable is the number of people who spent the night in the household.
  • Entity polygon
The entities worked on have a geographical footprint; their sizes differ, some significantly larger than others. With the help of entities, a separate form that selects the entity, a geoshape question is used to capture the shape of the entity and update the variable on the entity table.
Using the recently updated geofence function, the point captured is validated to ensure it falls within the polygon, which accommodates all entity sizes.
Part 3: ODK Setup and Data Flow
Entity registration form
survey sheet
type name label save_to calculation
select_one lga lga Select lga lga
select_one ward ward Select ward ward
select_one structures structure Select structure structure_name
calculate structure_label jr:choice-name(${structure},'${structure}')
geopoint gps_location Capture the location within the main structure location
select_one supervisor supervisor Select your supervisor code last_supervisor
date reg_date Registration date first_visit
calculation date last_visit ${reg_date}
begin_group section_a
Section A
end_group
choices sheet
list_name name label
structures structure_1 Structure 1
structures structure_2 Structure 2
structures structure_3 Structure 3
supervisor supervisor_1 Supervisor 1
supervisor supervisor_2 Supervisor 2
supervisor supervisor_3 Supervisor 3
entities sheet
list_name label
structures_list ${structure_label}
The form above creates an entity table called structure_list. The label of the structure is returned and used as the label for the entity added. Each submission adds an entity with its label and the following: lga, ward, structure_name, structure_label, location, last_supervisor, first_visit and last_visit
Follow-up form
survey sheet
type name label calculation relevant save_to
select_one_from_file structures_list.csv structure Select structure
calculate structure_label instance('structures_list')/root/item[name = ${structure}]/structure_label
calculate lga instance('structures_list')/root/item[name = ${structure}]/lga
calculate ward instance('structures_list')/root/item[name = ${structure}]/ward
note Confirm structuredetails: Structure: ${structure_label} LGA: ${lga} Ward: ${ward}
calculate instance('structures_list')/root/item[name = ${structure}]/location
geopoint structure_gps Capture the GPS coordinates of the structure.
calculate gps round(distance(concat(${structure_gps},;,${gps}),2)
note distance Your distance to the selected structure is ${distance} meters. You are out of range ${distance} > 50
begin_group section_a Section A ${distance} <= 50
date visit_date Select the date of visit last_visit
end_group
entities sheet
list_name name update_if
structures_list ${structure} true()
There are multiple follow-up forms, and all follow a similar structure to that above. For each of the follow-up forms, the entity is selected, some attributes are pulled and displayed to the user to verify the entity. The location is also pulled and compared to the supervisor's current location. For these follow-up forms, they need to be within a 50-meter radius of the structure to proceed. The entity is also updated with the name of the supervisor and the data visited, which is possible by specifying true() under the update if column on the entities sheet.
If they are out of the 50-meter radius, they receive an error message and the distance between them and the facility, which also helps to let them know if they are close to the structure or not.
Images Form
Most of the data points collected require an image to be captured for verification and tracking over time.
A separate form was created and deployed alongside a corresponding follow-up form, another supervisor was responsible for capturing the images as the main follow-up form is administered.
This form would update the entity table with the name of the supervisor who administered the image tool.
Polygon form
survey sheet
type name label calculation save_to
select_one yn structure_fenced Is the structure fenced fenced
select_one yn gate Does the structure have a gate gate
note The next question will allow you to capture the shape of the structure. Follow the steps below to capture the shape of the facility. 1. Click on 'Get polygon' 2. Click on Add Location 3. Select Manual location recording 4. Move to the 4 corners (or more) of the structure and record a point at each corner 5. When you are done, save it using the floppy disk icon at the bottom right
geoshape structure_polygon Trace the perimeter of the facility structure_shape
select_one supervisor supervisor Select your supervisor code polygonization_by
choices
yn yes Yes
yn no No
entities
list_name entity_id update_if
The form above is used to collect the polygon of the structure, some are fenced, making it easier to pick the points for the perimeter, others are not. The supervisors have to rely on the staff in those structures or the people of the community.
With the polygon of each structure stored, now the validation is more accurate, ensuring that a supervisor is within the perimeter of the structure before their forms are enabled.
The form below shows an updated version of the GPS validation using a polygon instead of the radius.
calculate structure_polygon instance('structures_list')/root/item[name = ${structure}]/structure_shape
geopoint gps Capture the GPS coordinates of the structure.
calculate distance round(distance(concat(${structure_gps},;,${gps}),2)
note Your distance to the selected structure is about ${distance} meters. You are out of range not(geofence(${gps}, ${structure_shape}))
begin_group section_a Section A geofence(${gps}, ${structure_shape})
end_group
Part 4: Additional forms and features
With the possibility of connecting a single table in multiple forms with entities, other features were given birth to. One of the notable ones was the entity locator.
  • Entity Locator Form
The structures in the study are not usually easily located, especially ones in semi-urban and rural areas, a facility locator form that pulls the location and extracts the longitude and latitude, then dynamically creates a google maps URL that opens a navigator to the structure to guide the enumerator or a supervisor to the structure - (I wanted to use the ex: to open the google maps or another maps application on the device but couldn't in time, so I went with this work around, should be a section under support I guess)
Here is the structure of the form
calculate structure_gps instance('structures_list')/root/item[name = ${structure}]/location
calculate lat selected-at(${structure_gps},0)
calculate long selected-at(${structure_gps},1)
note Your distance to the selected structure is about ${distance} meters. ${gps}!=""
calculate lat_long concat(number(${lat}),,,number(${long}))
calculate gps_url concat(https://www.google.com/maps/search/?api=1&query=,${lat_long})
note Click to see the [location in maps] (${gps_url})
Just in time, as ODK Central enabled deletion of submissions, any submission from that form was deleted, as it was only required to be a utility form for navigation, not data collection.
  • Entity Update Form
This feature was not implemented in the study, but was a workaround to a limitation we faced with entities.
Even though ODK Central allowed for editing submissions, any edit made on the form was not reflected in the entity table [add ODK docs highlighting that limitation]. The entity update form will be an EXACT replica of the form used in any follow-up visits, but without any constraints as the finalised form used in the field, no required questions, no relevant questions, and no location validation. This form is only available to the supervisory team and managers.
When an edition needs to be made on the entity, the supervisor picks the form that was used with the error, selects the entity, populates only the questions that need to be edited, and then submits. This will then update the entity with the only question answered.
Part 5: Challenges and Solutions
The workflow came with some challenges, we were able to find a workaround for most of them and others, we adopted them the way they were:
  1. Editing a form does not update the entities table. We employed the workaround of editing both simultaneously, and later had the idea of using a form dedicated to update, as highlighted in part 4; although that wasn't deployed in the live data collection
  2. Enumerators found it difficult to locate the structures as they were constantly rotated to reduce familiarity bias; the facility locator tool served as a guide to access the structures
  3. Although the geofencing feature ensured the form opened within the structure, it does not prevent filling the form outside the fence after accessing it. The forms were then opened within a window during the expected times of reporting, except for the entity locator
  4. The images captured for each data point made the tool longer and delayed submission due to the sizes of the images; the tools were then separated into 2 - follow-up tool A & follow-up images tool A
Absolutely thrilled to see our workflow featured here and even more excited to have been part of this journey! Implementing longitudinal data collection using entities in ODK opened up a whole new world of possibilities for us, especially in managing data across rural, sub-rural, and urban LGAs over several months. The ability to track and update entities made the process seamless and much more efficient.
Working on this project was a fantastic learning experience. I gained deeper insights into how ODK’s entity feature can transform data workflows and enable more accurate, actionable insights. Collaborating on the design and implementation taught me the value of teamwork and innovative thinking in solving real-world challenges.
A special shoutout to @Yakub, who designed the workflow and took the lead in sharing our experience on the ODK showcase forum. Your vision and dedication were key to making this a success, and I truly appreciate your partnership throughout the process.
What’s most rewarding is seeing the real-world impact: the data we collected is already informing better decision-making and resource allocation in communities that need it most. Knowing our work is helping to improve lives and drive positive change is incredibly fulfilling. Looking forward to more impactful projects together!
The study is in Kaduna, Nigeria, and it is focused on tracking Human Resources for Health (HRH) and supply chain data. Aimed to move beyond single snapshots to understand the true movement and trends in availability and commodity accessibility for clients over time.
For this pilot, four Local Government Areas (LGAs) were selected. We deployed over 100 dedicated community data collectors, who diligently gathered data from approximately 80 health facilities fortnightly over a six-month period.
This effort has gathered 15,000+ hours of data collection by the data champions! Their commitment is vital in providing a rich dataset that reveals trends, unlike traditional cross-sectional data, which offers only a single point-in-time view.
Another component of this initiative is the ability to map health facilities and calculate demand for specific areas. This also helps us understand the relationship between different facilities, allowing us to track the movement of essential items like vaccines and other community health commodities between them.
This pilot demonstrates the power of continuous data collection in providing a clearer, more dynamic picture of our health systems.
(post deleted by author)
