How can i make a group of questions be repeated based on a (yes or no
question) is that possible? for example i want to ask the user the
following question :
Do you want to count more items?
if the user says yes i want to ask him/her a group of questions and at the
end of this group of questions i want to ask the same question:
Do you want to count more items? if the answer is yes i want to repeat the
same group of questions and if the answer is no i want to break the loop
is this possible???
Hi? Try this.
Make group repeat (begin_repeat) relevant based on Yes/No Response i.e.
${Yes/No}='Yes'. This will make The grouped repeat questions appear if
previous response is Yes.
The group repeat questions will be repeated endlessly until you refuse to
add group.
On Tue, Jun 7, 2016 at 11:16 AM, wrote:How can i make a group of questions be repeated based on a (yes or no
the same group of questions and if the answer is no i want to break the
loop
is this possible???--
i actually tried that and it entered the loop,and when i chose the yes
option it displayed a (Add a new Group) which i could not understand what
did it mean, and also if i select the no option it will also display (Add a
new Group) and will leave the loop
Make that group relevant based on Yes/No Response. Send me what you are
working on if its okay with you. I can see what I can I do.
On Wed, Jun 8, 2016 at 8:45 AM, wrote:i actually tried that and it entered the loop,and when i chose the yes
new Group) and will leave the loop--
Hello, I've the same concern.
I tried to create a begin_repeat, however, when I export the collected data
to XLS file, the answers is only a link that send me to see the answers on
the web browser. Is there a way to plot the answers directly in the XLS
file?
Thanks!
Em quarta-feira, 8 de junho de 2016 02:56:22 UTC-3, Louis Omoya escreveu: > > Make that group relevant based on Yes/No Response. Send me what you are > working on if its okay with you. I can see what I can I do. > > On Wed, Jun 8, 2016 at 8:45 AM, <mostafa...@gmail.com > wrote: > >> i actually tried that and it entered the loop,and when i chose the yes >> option it displayed a (Add a new Group) which i could not understand what >> did it mean, and also if i select the no option it will also display (Add a >> new Group) and will leave the loop >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > >Gustavo,
Use Briefcase. https://opendatakit.org/use/aggregate/data-transfer/#Exporting
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Wed, Jun 8, 2016 at 10:06 AM, Gustavo Zanfra Paitch gpaitch@gmail.com wrote:
file?Thanks!
working on if its okay with you. I can see what I can I do.On Wed, Jun 8, 2016 at 8:45 AM, mostafa...@gmail.com wrote:
