Manual StudyID Entry When QR Scanner is Down in the Field
Hi, I'm using ODK Collect on an Android Nexus 7 (Android version 6.0.1). In the field (Zambia), the barcode scanner occasionally will not work, so I cannot use a "yes" required function in the survey. Is there a way to use relevant/constraint so that if the barcode "type" question is skipped (when the scanner is not working) that a field for manual study ID entry comes up?
Thanks! Amy
Probably you want something like attached XLS barcode.xlsx (8.6 KB)
Thanks - that's really helpful and worked well!
