Some forms have failed to upload to 'Googlesheets', they are trapped in 'Edit Saved Form' (this is an outstanding support issue entitled 'ODK Collect - Unable to 'save' a survey'). How can I (manually) upload the forms and media to googlesheets? Is it actually possible to do this? When I used 'aggregate' you could use 'ODK-Briefcase' to do this so can this still be used with Googlesheets?
I am using a Samsung Tab Active 3 with Android 11. Uploading to Googlesheets
Tried to use 'ODK-Briefcase' but failed. Won't allow connection details to be specified to the sheet.
Not aware unless other users have had similar issue.
