I want to administer a survey to the public which will do the following
Take GPS coordinates
Map using the placement map appearance
Capture image and audio of the place being mapped
Capture also a video recording
Respond to a set of questions using star rating (ranking)
After answering these questions, I then want to move to the next location to be mapped and I want to continue to track GPS coordinates from the previous location to this next location.
At the next location, I want to repeat Number 1 to 6 above. The repeat will be continued until all possible locations are mapped and attached questions responded to.
The number of locations that will be mapped are unknown ahead.
My question is with my syntaxing and design of my XLSform, is my use of repeat function right to allow me repeat the questions for each location mapped? Would I be able to capture tracks of GPS with this design between points?
This is my first test of ODK and XLSform and I am not a programmer
I have designed my questions with relevant constraints and hints in XLSform. I want to be able to use it on ODK collect
I have used a repeat function, but am not getting headway with this because am not sure an using the right function or placing the repeat in the right place or if the geotrace would capture the GPS points in between locations
5. Anything else we should know or have? If you have a test form or screenshots or logs, attach below. My xlsx form is as attached
MapandDocConcerns.xlsx (11.3 KB)
