We've run into a bug that is proving very difficult to reproduce consistently. On some mobile devices the map view doesn't show up when using geopoint, geotrace or geoshape. I've been able to reproduce this on my own phone when I have this ODK based app installed (https://play.google.com/store/apps/details?id=hosm.odk.collect.android). This hasn't been the case with other phones, in some cases the same phones one will work and another won't. (I don't have details on make or version of android on those phones) I do have one phone running Cyanogen 13.1.1/Android 6.0.1 on it that has the issue.
Any ideas what this might be? I can also do some more troubleshooting on the device if there are suggestions on how I should do that.
Are you able to reproduce this issue on a stock version of ODK
Collect? If so, what version? And what steps do you take to get that
behavior?
On Wed, Sep 21, 2016 at 11:17 PM, wrote:
> Hi All,
> Thanks,
> -Kate
> You received this message because you are subscribed to the Google Groups "ODK Developers" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
Sorry I should have been more clear. I've been able to reproduce it in a
stock version of ODK with the other forked version installed. This
information might be completely unrelated, since I couldn't find any other
versions/clones of ODK on the other device have the issue.
The problem I'm reporting is on stock instances of ODK running version
1.4.10.
The steps I take to get the issue are:
Download form
Click Fill Blank Form
Begin answering and swiping through questions
Come to location question
A text box appears instead of a button to "Start GeoPoint" or "Start
GeoShape" or "Start GeoTrace" (depending on the form)
-Kate
On Thu, Sep 22, 2016 at 7:23 AM, Yaw Anokwa wrote:
Hi Kate,
behavior?
my own phone when I have this ODK based app installed ( https://play.google.com/store/apps/details?id=hosm.odk.collect.android).
On Thursday, September 22, 2016 at 10:43:24 AM UTC-4, Kate Chapman wrote:
> Hi Yaw,
> 1.4.10.
> 1. Download form
> 2. Click Fill Blank Form
> 3. Begin answering and swiping through questions
> 4. Come to location question
> 5. A text box appears instead of a button to "Start GeoPoint" or "Start
> Thanks,
> -Kate
> On Thu, Sep 22, 2016 at 7:23 AM, Yaw Anokwa <yan...@nafundi.com > wrote:
>> Hi Kate,
>> behavior?
>> Yaw
>> On Wed, Sep 21, 2016 at 11:17 PM, <kcha...@cadasta.org > wrote:
>> > Hi All,
>> > Thanks,
>> > -Kate
> *Kate Chapman*
> Chief Technology Officer *//* Cadasta
> kchapman@cadasta.org */**/* +1 703 673 8834
> cadasta.org *//* @CadastaOrg
So the issue is only on a few phones, not all. Also on the phones where it
is a problem it works fine with GeoODK, just not with ODK (not sure if this
tidbit is helpful).
My guess would be that something is not right with the form. If the
widgetFactor (which handles which widget to present) of ODK does not
know/read the data types correctly and the appearances attributes it uses
the default widget (StringWidget). Which that is what your seeing. Not
100% but im sure the issue can be traced by debugging here https://github.com/opendatakit/collect/blob/master/collect_app/src/main/
java/org/odk/collect/android/widgets/WidgetFactory.java
Can you share the form. I have also attached a sample stock ODK GeoWidgets
form for reference.
Jon
Hi Yaw,
1.4.10.
Download form
The widgets you use in the form aren't currently supported in the
version of Collect in the play store. When you say "I've been able to
reproduce it in a stock version of ODK" what exactly do you mean?
On Fri, Sep 23, 2016 at 6:06 PM, Kate Chapman wrote:
> Thanks Jon,
> tidbit is helpful).
> This is the form we have working with:
> https://s3-us-west-2.amazonaws.com/cadasta-resources/sample-forms/minimum_cadasta_questionnaire-all-geo.xlsx
> Thanks,
> -Kate
>> the default widget (StringWidget). Which that is what your seeing. Not 100%
>> https://github.com/opendatakit/collect/blob/master/collect_app/src/main/java/org/odk/collect/android/widgets/WidgetFactory.java
>> form for reference.
>> Best,
>> Jon
>>> Hi Yaw,
>>> 1.4.10.
>>> 1. Download form
>>> Thanks,
>>> -Kate
>>>> Hi Kate,
>>>> behavior?
>>>> Yaw
>>>> > Hi All,
>>>> > Thanks,
>>>> > -Kate
>>> Kate Chapman
>>> Chief Technology Officer // Cadasta
>>> kchapman@cadasta.org // +1 703 673 8834
>>> cadasta.org // @CadastaOrg
> Kate Chapman
Thanks for the information, super weird that they are working on some
devices then.
Reproducing it I meant that I was downloading ODK from the Google Play
store. Not using a fork of it or anything odd.
-Kate
On Wed, Oct 5, 2016 at 9:17 PM, Yaw Anokwa wrote:
Hi Kate,
it
this
tidbit is helpful).
uses
100%
GeoWidgets
form for reference.
Jon
Hi Yaw,
a
other
1.4.10.
Download form
when using
my own
phones
version of
13.1.1/Android
troubleshooting
MapView will not display if you do not have Google Play Services installed
on your device. It also may not display if you don't have Google Maps
installed or if you have rooted your device (not sure about that).
It needs a Google Maps service to vend the mapping tiles for the display.
If it cannot connect to that service, it falls back to the non-maps display.
On Wed, Oct 5, 2016 at 5:05 PM, Kate Chapman wrote:
Hi Yaw,
devices then.
it
this
tidbit is helpful).
uses
100%
GeoWidgets
form for reference.
Jon
Hi Yaw,
in a
other
1.4.10.
Download form
"Start
when using
on my own
collect.android).
same phones
version of
13.1.1/Android
troubleshooting
