Please I want to know the maximum character length for label in ona
Hello Gombe,
Currently, there is no maximum character length for the label in Ona. However, depending on the tool you are using (ODK Collect vs. Enketo), the amount of scrolling you may need to do to get the next question will depend. Also, due to a different format in ODK Collect, you may want to break the label into multiple row by using a note question type.
Could you provide more context, such as the text you want to put in the form? This would allow me to provide you better guidance.
Regards,
Megan
Thanks I think I am satisfied.
