Hello,
My survey only allows me to enter 9 digits in my integer field. Is it
possible to make it so I can enter more?
Thanks ![]()
Hello,
Thanks ![]()
by the way, am writing this in excel
You can check the old mails on this. This question came up before.
Basically, you will need to change your type to a text format and not an
integer number. Not sure in excel how to do. By default, regular integer
numbers in java can only go as high as 2.3 billion (2 to the 31st power).
Thus, collect only allows integer inputs with 9 digits (999,999,999).
Hello,
possible to make it so I can enter more?Thanks
Curtis BRODERICK
Head of training and user support
Tél : + 33(0)1.53.02.40.61 06.15.33.57.37
Health Information System
-----------------------www.epiconcept.fr------------------------
Ce message et toutes les pièces jointes sont établis à l'intention
exclusive de ses destinataires et sont confidentiels.
Si vous recevez ce message par erreur, merci de le détruire et d'en
avertir l'expéditeur.
The information contained in the Email and any attachments is
confidential and intended solely and for the attention and use of the
named address(es). It may not be disclosed to any other person without
the express authority of EpiConcept, or the intended recipient, or
both.
If you are not the intended recipient, you must not disclose, copy,
distribute or retain this message or any part of it.
Я, Лисаченко Ганна Іванівна, група МОп-12, інститут менеджменту,
даю згоду на отримання інформаційних листів від "Інтернет-системи ІНВ".
Thank you. Yes I read the old mails about this but I was hoping there was a
way to do it without changing it to text as that means the user has to flip
back and forth between keypads.
Thus, collect only allows integer inputs with 9 digits (999,999,999).2012/8/28 Imobi larisa@imobi.co.za
Hello,
Curtis BRODERICK
Head of training and user supportTél : + 33(0)1.53.02.40.61 06.15.33.57.37
Health Information System47, rue de Charenton - 75012 PARIS Tel : +33 (0)1 53 02 40 60 Fax : +33 (0)1 53 02 40 62-----------------------www.epiconcept.fr------------------------
Ce message et toutes les pièces jointes sont établis à l'intention exclusive de ses destinataires et sont confidentiels.
Si vous recevez ce message par erreur, merci de le détruire et d'en avertir l'expéditeur.The information contained in the Email and any attachments is confidential and intended solely and for the attention and use of the
named address(es). It may not be disclosed to any other person without the express authority of EpiConcept, or the intended recipient, or both.If you are not the intended recipient, you must not disclose, copy, distribute or retain this message or any part of it.
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
I see the documentation is behind on this. If you specify
appearance="numbers" in the prompt of a string field in a form, it
will use the numeric keypad for string entry.
a way to do it without changing it to text as that means the user has to
flip back and forth between keypads.On Tue, Aug 28, 2012 at 10:29 AM, Curtis Broderick < c.broderick@epiconcept.fr> wrote:
Hello,
Curtis BRODERICK
Systèmes d'Information en SantéHealth Information System 47, rue de Charenton - 75012 PARIS Tel : +33 (0)1 53 02 40 60 Fax : +33 (0)1 53 02 40 62-----------------------www.epiconcept.fr------------------------
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Thanks!
will use the numeric keypad for string entry.Mitch
Hello,
Curtis BRODERICK
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
mitchellsundt@gmail.com--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
