Has there ever been an attempt to make a version of ODK Collect with
Mesh4x capabilities? Eventually, we will be seeking to have the
capability to conduct repeat household surveys, in which records could
be retrieved and updated. It seems that Mesh4x implemented in the
JavaRosa client allows synchronization to download entries and make
changes (http://code.google.com/p/mesh4x/wiki/JavaRosaDemo). How
difficult would it be to integrated Mesh4x with ODK Collect? I think
this is a function that would be very important for many surveys, not
just our own. Thanks!
i think a lot of people would like the functionality you've described.
we've just begun our exploration of the sync and database connection
options and it'll likely be a while before we have anything to show.
yaw
On Sun, Apr 10, 2011 at 20:39, David wrote:
> Dear all,
> Best,
> David
Thanks for your reply. Do you have an idea of the number of programming
hours/costs entailed in building this functionality? It seems as though
Mesh4x should help with this - particularly if it could be augmented to work
with Google Fusion Tables, rather than Spreadsheets.
Thanks!
David
On Mon, Apr 11, 2011 at 12:11 PM, Yaw Anokwa wrote:
david,
no clue on how long it'd take. i'd recommend you someone like http://dimagi.com if you want to get a reasonable estimate.
yaw
On Sun, Apr 10, 2011 at 23:05, David A. Raitzer wrote:
> Yaw,
> Thanks!
> Best,
> David
>> david,
>> yaw
>> > Dear all,
>> > Best,
>> > David
I think looking at using CouchDB as a datastore for ODK vs implementing
mesh4x might be a nice way of handling what you're describing in terms of
synching.
On Mon, Apr 11, 2011 at 4:59 PM, Yaw Anokwa wrote:
david,
work
Thanks!
David
On Mon, Apr 11, 2011 at 12:11 PM, Yaw Anokwa yanokwa@gmail.com wrote:
david,
agreed with matt, that couch is probably the way to go. case in point, http://www.groupcomplete.com has a build of odk collect that uses some
couch pieces.
> synching.
>> david,
>> yaw
>> > Yaw,
>> > work
>> > Thanks!
>> > Best,
>> > David
>> >> david,
>> >> yaw
>> >> > Dear all,
>> >> > could
>> >> > Best,
>> >> > David
Perhaps this might be a naive question, but Fusion Tables can export
values as KML, which is a form of XML that is not all that different
from the submitted forms. Might be possible somehow to use that XML
generation capacity to regenerate the form again in collect as a saved
but unfinished form when the user so desires? My thinking is that if
the repeat survey is done with a live internet connection, the
enumerator could identify the households by proximity via Google Maps,
and then send a query to Fusion Tables that would send the xml back to
Collect. If each record has a unique ID, then the new observations
can be submitted again to Aggregate and subsequently linked directly
to the prior ones.
Just an idea...
David
On Apr 12, 5:31 am, Yaw Anokwa wrote:
> agreed with matt, that couch is probably the way to go. case in point,http://www.groupcomplete.comhas a build of odk collect that uses some
> couch pieces.
> https://github.com/dimagi/cushions#readmehas good first pass at
> getting mobile to server going. mobile to mobile can be done if you
> can get couch running on the phone (seehttp://wiki.apache.org/couchdb/Installing_on_Android).
> > synching.
> >> david,
> >>http://dimagi.comif you want to get a reasonable estimate.
> >> yaw
> >> > Yaw,
> >> > work
> >> > Thanks!
> >> > Best,
> >> > David
> >> >> david,
> >> >> yaw
> >> >> > Dear all,
> >> >> > could
> >> >> > Best,
> >> >> > David
> >> >> > Options:http://groups.google.com/group/opendatakit?hl=en
while that is certainly possible, i don't think that's the right approach.
we need to support a workflow-centric model of form completion. one of
our todos over the next few months is to design an elegant way to do
that.
> to the prior ones.
> Just an idea...
> Best,
> David
>> couch pieces.
>> > synching.
>> >> david,
>> >> yaw
>> >> > Yaw,
>> >> > work
>> >> > Thanks!
>> >> > Best,
>> >> > David
>> >> >> david,
>> >> >> yaw
>> >> >> > Dear all,
>> >> >> > could
>> >> >> > Best,
>> >> >> > David
